    Sep 2013
    australia
    Using Google I was able to download movies from utube with internet download manager always came in mp4 format
    Latest IDM download made me switch to Google Chrome to download movies using the same program. the movies now come down as mkv that I can no longer convert to mpeg2 using format factory.
    IS there any way to get utube downloading to mp4 again or any other way to fix the problem so as I can play on my player
    since writing this post I have found that my u torrent download is also mkv opens with windows media player which fails to work when requested , so it seems all video downloads are now mkv format
  2. Your download tools probably use mkv since you are downloading streams which are using vp8/vp9 video (and probably ogg vorbis audio), which can not be packed into mp4.
    users currently on my ignore list: deadrats, Stears555
  3. Can you post example link to youtube video that came in mkv?
  4. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    If it was vp8 or vp9, shouldn't it have used .webm instead of .mkv?
    Anyway, you can use: http://www.clipconverter.cc/
  5. If it was vp8 or vp9, shouldn't it have used .webm instead of .mkv?
    just a choice of the programmer (+ webm = restricted mkv)
