Results 1 to 9 of 9
    Jul 2014
    Númenor
    How can I do this? I've looked arround and found that I can demux the file; I'm guessing I will have to remux it after that.
    Is there a way to do this without having to demux and remux? I dont have any ifo files so I cant really use ifoedit.
    Mar 2008
    DGindex, perhaps ?
    Jul 2014
    Númenor
    DGindex, perhaps ?
    I tried it out but its only demuxing. I want to remove the other streams completely.
    canada
    Use ifoedit to reauthor the vobs and use dvdshrink to remove the unwanted audio.
    Jul 2014
    Númenor
    How do I reauthor them? Whenever I use the create new vob is says "no vob units found" or something.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Open ifoedit and look on the bottom taskbar and click on create IFO'S.
    Jul 2014
    Númenor
    Like I said in the main post and a few moments ago I cant use ifoedit because I get this error:
  8. I'm a Super Moderator johns0's Avatar
    canada
    Did you click on the create ifo button and go to the first vob and add it?If it didn't work right then you're doing something wrong.
    Jul 2014
    Númenor
    I have only 1 vob file and that is the one I select
