Results 1 to 12 of 12
    Jul 2014
    argentina
    Hi to all!
    I hope you guys are doing ok.
    I recently bought myself an ASUS BW-12B1ST blu-ray burner and while the first few days it worked wonderfully, now it is ruining every blank bluray disc I try to burn.
    When recording reaches 99% the recording fails and the blu-ray is not usable.
    I tried Nero 12 and DVD FAB 9 with the same results.
    The message is "invalid address for write".
    I don't know if the problem is the PC (Windows 7 64-bit), the burner or the discs.
    Can anyone help me please?
    I don't know what to do!
    Thanks in advance,
    Javier
    PS.
    Windows 7 64 BITS
    AMD ATHLON II X4 620 2.60 GHZ
    MEMORY 4 GB
    This is from the Nero log:
    16:14:11 #122 Text 0 File Cdrdrv.cpp, Line 1274
    : Queue again later
    - 16:14:11.682
    16:14:11 #123 Text 0 File Cdrdrv.cpp, Line 1274
    : Queue again later
    - 16:14:11.702
    16:14:11 #124 Text 0 File Cdrdrv.cpp, Line 1274
    : Queue again later
    - 16:14:11.721
    16:35:05 #125 SPTI -1135 File SCSIPassThrough.cpp, Line 224
    CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
    CDB Data: 0x2A 00 00 A7 BA 40 00 00 20 00 00 00
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
    Buffer x1435fac0: Len x10000
    0xAD 80 EB AE D7 F2 EE 54 05 00 04 A8 E3 AB 67 8C
    0xE2 DD 82 EA 78 74 F3 CF 9C 6E E0 1B 89 EA E8 8D
    0x6B 00 46 E8 A4 8E 3B D2 95 6D 89 2C 48 FC 93 10
    16:35:05 #126 TRANSFER -20 File ThreadedTransfer.cpp, Line 1233
    Could not perform Write
    16:35:05 #127 CDR -1135 File Writer.cpp, Line 339
    Write error
    E: ASUS BW-12B1ST
    16:35:15 #128 Text 0 File DVDPlusDualLayer.cpp, Line 1462
    SetDriveCaps: Set LAST LBA of layer 1 to 0
    16:35:15 #129 PHASE 38 File dlgbrnst.cpp, Line 2066
    Burn process failed at 4x (17.980 KB/s)
    16:35:16 #130 Text 0 File SCSIPTICommands.cpp, Line 301
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    16:35:16 #131 Text 0 File Cdrdrv.cpp, Line 12127
    DriveLocker: UnLockVolume completed
    16:35:16 #132 Text 0 File SCSIPTICommands.cpp, Line 464
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Nov 2003
    West Texas
    This shows a problem with your choice of blank discs in this burner. What type of discs are you using?
    Try ImgBurn instead of Nero. And tell us the MID code of the discs. Put a blank disc in the drive, start ImgBurn and click Discovery. The MID code will show up on the right side of the window.
    You weren't burning all that fast, at 4x, so that probably wasn't part of the problem.
    Jul 2014
    argentina
    Thank you for your response, Kerry!
    Discs I use are TDK. Should I try HP? I have a spindle of those as well.
    This is what IMGBURN says
    ASUS BW-12B1ST 1.03 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12.219.392
    Free Space: 25.025.314.816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next Writable Address: 0
    MID: RITEK-BR3-000
    Supported Write Speeds: 4x, 6x, 8x, 10x, 12x
    Disc Definition Structure:
    Certified: No
    Scanned: No
    Manufacturers Name: ASUS BW-12B1ST 1
    Additional ID: PLDS
    Serial Number: C5D0CL223925
    BD Disc Information:
    Disc ID: RITEK-BR3-000
    Disc Type: BD-R
    Disc Size: 120 mm
    Disc Class: 0
    Disc Version: 1
    Number of Layers: 1
    Layer Type: Writable
    DVD Layer Present: No
    CD Layer Present: No
    Channel Bit Length: 74.50 nm (25 GB Per Layer)
    Push-Pull Polarity: Positive
    Recorded Mark Polarity: HTL
    BCA Present: Yes
    Maximum Transfer Rate: Not Specified
    First PAA of Data Zone: 131.072
    Last PAA of Data Zone: 1.658.494
    Format Capacities:
    DT: 0x01 - NB: 12219392 (0x00BA7400) - TDP: 200704
    FT: 0x00 - NB: 11826176 (0x00B47400) - TDP: 12288
    FT: 0x32 - NB: 11826176 (0x00B47400) - TDP: 0
    FT: 0x32 - NB: 5796864 (0x00587400) - TDP: 0
    FT: 0x32 - NB: 12088320 (0x00B87400) - TDP: 0
    Performance (Write Speed):
    Descriptor 1...
    -> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00
    -> EL: 12219391 (0x00BA73FF)
    -> RS: 35.960 KB/s (8x) - WS: 17.980 KB/s (4x)
    Descriptor 2...
    -> RS: 35.960 KB/s (8x) - WS: 26.970 KB/s (6x)
    Descriptor 3...
    -> RS: 35.960 KB/s (8x) - WS: 35.960 KB/s (8x)
    Descriptor 4...
    -> RS: 35.960 KB/s (8x) - WS: 44.950 KB/s (10x)
    Descriptor 5...
    -> RS: 35.960 KB/s (8x) - WS: 53.940 KB/s (12x)
    Nov 2003
    West Texas
    MID: RITEK-BR3-000
    This is not good news. Ritek is probably my least favorite for Blu-ray media. The BR3-000 discs probably should not fail completely as you have been experiencing, but Ritek discs do not have a great reputation, either for good burns or longevity. I had a few that I burned back in 2008 (all BR2-000), and all of them lost data and became unreadable in three to four years.
    We generally recommend Verbatim brand discs (only the HTL variety, not their LTH discs). Other good ones include Panasonic and FTI/Falcon, which may be hard to find in Argentina.
    Load one of the HP discs and see what they say for MID code. And you might try burning one of the Ritek discs in ImgBurn at 2x and see if that helps. Edit: No, scratch that, it looks like they aren't supported at that low speed.
    Jul 2014
    argentina
    MID: RITEK-BR3-000
    Hi Kerry and thank you again. This is the info on the HP discs.
    Disc Information:
    Status: Empty
    Erasable: No
    MID: CMCMAG-BA5-000
    The only available brands in Argentina are TDK, LSK, Ridata and HP.
    Should I try the HP disc?
    Nov 2003
    West Texas
    Yes, the CMC discs should be better. Burn at 4x.
    Ridata will be Ritek (its their own brand). And as you've found out, the TDK discs are Ritek too. I haven't heard of the LSK brand, so I cannot advise you on them.
    Jul 2014
    argentina
    I am trying the Hp as I write. If indeed this one dies while finishing disk should I assume my burner is the problem?
    Jul 2014
    argentina
    UPDATE:
    The HP disc burned correctly.
    Now I am trying another TDK and tomorrow I'll try another HP and post the results here.
    What is weird is how come I managed to burn successfully aroun 15 TDK BRD before they started to fail.
    I looked for firmware updates at ASUS but there was nothing.
    Nov 2003
    West Texas
    Good to hear that the HP CMC disc burned correctly. The Ritek discs are just unpredictable in the way they burn, and in how well they retain data over time.
    The ASUS BW-12B1ST comes in two varieties. Asus doesn't make their own drives, they just rebadge drives made by other companies. Some are clones of the Lite-on iHBS112-2, but there are others that are clones of the LG BH14NS40. There are a lot of warnings over at MyCE about trying to crossflash the firmware of these drives, so probably best to wait for Asus to release one.
    Since your firmware is revision 1.03, it appears to be a Lite-on clone. http://club.myce.com/f87/how-upgrade-your-asus-bw-12b1st-liteon-ihbs112-2-a-331630/
    Jul 2014
    argentina
    So is it a good thing if it's a Lite ON?
    Nov 2003
    West Texas
    Depends on who you ask. I've never been a Lite-on fan, but they do have a reputation for dealing with mediocre media better than some other makes. But Lite-on always trailed LG and Pioneer in quality of burns in Blu-ray. Most at MyCE would tell you to buy a Pioneer if shopping for a Blu-ray drive, but since you already have this one, I'd say use it and don't worry about it. The very few people who still obsess over optical drives like to split hairs on the differences in quality results in their burns.
    Its getting harder to find the Lite-on Blu-ray drives in the US, and they may even be abandoning this type of drive.
    One good thing about Lite-on drives, you can test your burn results in a program called OptiDrive Control. You should be able to run the Quality test on all your burned discs. OptiDrive Control is a commercial program, but the trial would work for you for 30 days.
    Jul 2014
    argentina
    Thank you!
    I can report I burned 3 HP discs and all 3 were successful. Perhaps the TDK discs don't go well with this drive.
    Thank you very much for your help and assistance.
    You rock, Kerry!
    All the best from Argentina,
    Javi
