  1. Some one recommended using the filter dll from Aegisub and place it in the plugins directory of virtualdub in order to get UTF-8 subtitle support in Virtualdub. I tried placing the xy-vsfilter-aegisub32.dll (and changed the ext to .vdf) from Aegisub in either of the plugins and/or plugins32 directories under Virtrualdub 1.8.6 and I did not see a new filter appear in the filter list.
    What should I expect?
    Is this the correct way to get UTF-8 subtitle support for srt files under virtualdub?
    Thanks!
    Bob
  2. DECEASED
    Jun 2009
    Heaven
    Try changing the whole filename to "VSFilter.vdf", perhaps that makes some difference ---
    --- especially when you have a VERY-ancient version of VirtualDub
    Anyway, VSFilter gives you two new entries, namely TextSub and VobSub.
    If VirtualDub fails to load VSFilter, then something fishy is happening elsewhere on your system
