    Apr 2008
    Not sure where to ask this:
    I have never had problems with my little-used Panasonic VCR (PV-V4524S) VHS Player/Recorder.
    However, just today, tapes I have recorded at SPL speed are playing back at what appears to be SP speed.
    Ideas anyone?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I think you meant "SLP".
    I haven't had a VCR in years. But I recall one of my units had a button on the front panel and remote where you could manually change the speed. Which would alter playback. Newer units were automatic based on how they were recorded.
    Google is your Friend
  3. I'm a Super Moderator johns0's Avatar
    canada
    Sounds like you have a problem with the control head not switching to slp mode and stuck in sp,if the control head is coated with tape oxides try cleaning it,if that doesn't help then it's a major issue.
    Have you tried other tapes not recorded by that vcr in slp?
    Feb 2006
    Ideas anyone?
    try going into your player's settings and look for a "factory restore" setting. or you might
    try unplugging your player and waiting a few hours to see if that does any good.
    Apr 2008
    Don't have any idea why, but after fast winding and rewinding several times, my VCR seems to be working okay again. Thanks folks for your replies.
