    Jul 2014
    Australia
    I've tried all suggestions regarding downloading an M3U8 file with this link:
    http://recordtv-hls-production.s3.recordtv.com/103/103_2014-05_16-14-00_2.m3u8
    using this code got from IDM:
    ffmpeg -i "http://recordtv-hls-production.s3.recordtv.com/103/103_2014-05_23-14-00_2.m3u8" -c copy Video.mp4
    run as a batch file.
    But I get a
     [http @ 01D98BC0] HTTP Error 403 Forbidden
    http://recordtv-hls-production.s3.recordtv.com/103/103_2014-05_23-14-00_2.m3u8:
    Input/output error
    Tried to:
    1. Rename the output file as Video.ts, Video.mkv.
    2. Run the command without the -c copy parameters.
    3. Directly save it using VLC, but not only 2 minutes of chunks. (Not the entire 29 Minutes video)
    Any help would be appreciated. Thanks.
  2. Hi dmpiq ,
    Can you give us , the link where to watch the video ?
    Cheers .
    Jul 2014
    Australia
    Thanks for your reply.
    Here's the link:
    HTML Code:
    http://www.recordtv.com/#/watch/11465252
    Please note that in order to access it, you'll need to have a Singapore VPN or Proxy as it is region locked. Thanks.
  4. Hi dmpiq ,
    I won't use Singapore VPN or Proxy .
    Here below what I tried previously .
    With your link 103_2014-05_16-14-00_2.m3u8
    When VLC told error , i have caught informations , and done 2 files :
    ( NOTE : we can get the beginning for episodes from 1400 to 1430 )
    #EXTM3U
    #EXT-X-TARGETDURATION:100
    #EXT-X-ALLOW-CACHE:YES
    #EXT-X-VERSION:3
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1400-6093.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1400-6094.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1400-6095.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1400-6096.ts
    #EXTM3U
    #EXT-X-VERSION:3
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1401-6097.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1401-6098.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1401-6099.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1401-6100.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1401-6101.ts
    #EXTINF:10.000,
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1401-6102.ts
    @echo on
    ffplay -i "Essai_Chunk_1400.m3u8" -x 750 -y 550
    rem CLOSE the window , for watching the next one !!!
    ffplay -i "Essai_Chunk_1401.m3u8" -x 750 -y 550
    pause
    :fin
    Cheers .
    Jul 2014
    Australia
    Thanks, but I don't know what to do with the code that you sent me?
  6. Former Member
    Dec 2007
    You say that you want to download;
    So... then why do you use;
    as input to ffmpeg?
    The first one works fine as input to ffmpeg. If it is first one that you want to download, then why do you use the second one with ffmpeg?
  7. Hi dmpiq ,
    using http://recordtv-hls-production.s3.recordtv.com/103/103_2014-05_16-14-00_2.m3u8
    ( with firefox ) i got a file 103_2014-05_16-14-00_2.m3u8
    Essai_Chunk.m3u8 ( saving as , after having used text editor )
    #EXTM3U
    #EXT-X-PLAYLIST-TYPE:VOD
    #EXT-X-VERSION:3
    #EXT-X-TARGETDURATION:14
    #EXT-X-MEDIA-SEQUENCE:6093
    #EXTINF:13.32
    #EXTINF:10.04
    http://recordtv-hls-production.s3.recordtv.com/103/chunk-103_2-20140516_1430-6273.ts
    #EXT-X-ENDLIST
    NOTE :
    Origine for each line : chunk-103...
    Replaced by http://recordtv-hls-production.s3.recordtv.com/103/chunk-103...
    Made a batch file
    @echo on
    ffmpeg -i "Essai_Chunk.m3u8" -vcodec copy -acodec copy -f mpegts "Essai_Chunk.ts"
    pause
    :fin
    During the process
    ffmpeg version N-43206-gf857465 Copyright (c) 2000-2012 the FFmpeg developers
      built on Aug  4 2012 16:10:39 with gcc 4.7.1 (GCC)
      configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --en
    able-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-a
    mrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-li
    bnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth
    eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-l
    ibvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
      libavutil      51. 66.100 / 51. 66.100
      libavcodec     54. 49.100 / 54. 49.100
      libavformat    54. 22.100 / 54. 22.100
      libavdevice    54.  2.100 / 54.  2.100
      libavfilter     3.  5.102 /  3.  5.102
      libswscale      2.  1.100 /  2.  1.100
      libswresample   0. 15.100 /  0. 15.100
      libpostproc    52.  0.100 / 52.  0.100
    [mpegts @ 0292eb60] max_analyze_duration 5000000 reached at 5013600
    [mpegts @ 0292eb60] Could not find codec parameters for stream 0 (Unknown: none ([21][0][0][0] / 0x0
    015)): unknown codec
    Consider increasing the value for the 'analyzeduration' and 'probesize' options
    [mpegts @ 0292eb60] Estimating duration from bitrate, this may be inaccurate
    [hls,applehttp @ 003ec520] max_analyze_duration 5000000 reached at 5013600
    [hls,applehttp @ 003ec520] Could not find codec parameters for stream 0 (Unknown: none ([21][0][0][0
    ] / 0x0015)): unknown codec
    Input #0, hls,applehttp, from 'Essai_Chunk.m3u8':
      Duration: 00:28:56.00, start: 12830.997478, bitrate: 0 kb/s
        Stream #0:0: Unknown: none ([21][0][0][0] / 0x0015)
        Stream #0:1: Video: h264 (Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9
    ], 25 fps, 25 tbr, 90k tbn, 50 tbc
        Stream #0:2: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, s16, 139 kb/s
    [mpegts @ 032f3d00] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
    Output #0, mpegts, to 'Essai_Chunk.ts':
      Metadata:
        encoder         : Lavf54.22.100
        Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=2-31,
    25 fps, 90k tbn, 25 tbc
        Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, 139 kb/s
    Stream mapping:
      Stream #0:1 -> #0:0 (copy)
      Stream #0:2 -> #0:1 (copy)
    Press [q] to stop, [?] for help
    frame=  199 fps=131 q=-1.0 size=    1037kB time=00:00:07.99 bitrate=1061.8kbits/s
    frame=45229 fps= 36 q=-1.0 Lsize=  228686kB time=00:30:09.10 bitrate=1035.5kbits/s
    video:177082kB audio:28819kB subtitle:0 global headers:0kB muxing overhead 11.066200%
    Got a file "Essai_Chunk.ts" , converted after in "Essai_Chunk.mp4"
    Cheers .
    Jul 2014
    Australia
    thanks for the help, but I got the error message:
    Application provided invalid, non monotonically increasing dts to muxer in stream 1: 10622856 >= 10620028 av_interleaved_write_frame<>: Invalid argument
    After
    frame=2912 fps= 61 q=-1.0 size = 12405KB time=00:01:56.45 bitrate= 872.6kbits/s
    Any idea why?
