  1. I have the following programs/stuff already installed.
    - K-Lite Codec Pack
    - MKVToolNix
    - Aegisub
    - Handbrake
    - AviSynth 2.5
    - XviD4PSP 5
    - rebox.NET
    Computer specs.
    - Windows 7 Professional
    - Intel Core 2 Duo P8600 2.4 GHz
    - 4GB RAM
    First off, I don't know a whole lot about encoding/transcoding/muxing/etc so please bear with me. I have a .mkv file with .ass subs that I want to embed and ultimately convert into a file that can be played on my PS3. I've tried reading up on the subject but I'm getting overwhelmed. Help will be much appreciated.
    File information.
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 4.66 GiB
    Duration                                 : 1h 10mn
    Overall bit rate                         : 9 515 Kbps
    Encoded date                             : UTC 2013-04-08 23:15:53
    Writing application                      : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct  9 2011 11:55:43
    Writing library                          : libebml v1.2.2 + libmatroska v1.3.0
    Attachment                               : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
    Video
    Format profile                           : High 10@L5.1
    Format settings, ReFrames                : 16 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1h 10mn
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bit depth                                : 10 bits
    Writing library                          : x264 core 129 r2245+729M 1a52e03
    Encoding settings                        : cabac=1 / ref=16 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.70 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.80 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.10 / aq=1:0.50
    Language                                 : Japanese
    Default                                  : Yes
    Forced                                   : No
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : A_AAC
    Duration                                 : 1h 10mn
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 KHz
    Delay relative to video                  : 9ms
    Language                                 : Japanese
    Default                                  : Yes
    Forced                                   : No
    Text
    Format                                   : ASS
    Codec ID                                 : S_TEXT/ASS
    Codec ID/Info                            : Advanced Sub Station Alpha
    Compression mode                         : Lossless
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    canada
    Instead of re-encoding with handbrakes just stream the mkv with Universal Media Server to your ps3,just name the sub the same name as the mkv.
  3. Originally Posted by johns0 View Post
    Hmmm. I've tried using PS3 Media Server and the quality was less than desirable. It has trouble with this particular file anyway. I'll try and see if that one runs better.
    Edit: Yeah, it has the same problem. I think there is something wrong with the subs. The video quality with the default settings was worse than PS3 Media Server.
