Results 1 to 9 of 9
    Jul 2014
    south-africa
    any ideas
  2. What kind of media have you tried?
    Jul 2014
    south-africa
    Mp4 mp3 avi
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Easy. Get the old plugin qt7plug.dll and copy for this path> C:\Program Files\Sony\Your Vegas version\FileIO Plug-Ins\qt7plug\
    On my PC enable open all mp4+mp3 and Avi + mp3
    Jul 2014
    south-africa
    OK I copied the file where do i find pc enable?
  6. mp4 and avi are containers that can hold different types of video audio and data information. Mediainfo can tell you more about what is in yours. Your installation sounds messed up. What version are you running? Is it a legal copy?
    Jul 2014
    south-africa
    yes it was workinf fine until the system I did the system restore I tried reinstalling it several times and no thinking maybe its time for a fresh copy of windows xp anyway
  8. Member DB83's Avatar
    Jul 2007
    Before you do that.
    Un-install the program
    Delete all temp files and folders for the program not un-installed as above (usually stored in documents and settings)
    If you can, start reg-edit and delete all references that still exist to the program
    Re-install the program
    But if you have issues with other programs a re-install of the OS may be a quicker option.
