Results 1 to 16 of 16
  1. This is a very simple GUI for ffmpeg x265 encoder that i find here I thought might be helpful .
    Download
    GUI for ffmpeg 32 x265.7z
    GUI for ffmpeg 64 x265.7z
    REQUIREMENT
    WINDOWS 7 or 8 AND Microsoft .NET Framework 4
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    It also runs in Linux, I've had on my Linux system for a while now and it is simple and works. Besides batch files, you can also encode ffmpeg x265 in virtual dub via external encoder, as well as Aviutl via ffmpeg export plugin.
    Feb 2010
    Germany
    it would be nice if it would eat MKV files at all and then if it accepts more than one audio track along with VobSub subtitles, because I have a huge collection of MKV files with more that one audio track and subtitles that I would like to convert with x265 to save space.
    Jul 2014
    Denmark
    Have you tried FFMpeg with FFQueue as GUI? Seems like it should be no problem to do that with a proper preset..
  5. Didn't realize these existed when I made this one:
    Yet Another X265 GUI (Yax265Gui)
    64 bit
    https://drive.google.com/file/d/0B695hmOChptNbERHeG41XzRSOE0/view?usp=sharing
    32 bit
    https://drive.google.com/file/d/0B695hmOChptNYXE4cFMtSjhOVXM/view?usp=sharing
    I would appreciate it if people helped me test it out. It requires that you unzip it on your main hard drive, and keep all the program files in the original folder, but it is very simple. Thanks in advance for your help.
    In the future, I'm hoping to (very) slowly add support for all the x265 parameters in the following style, please let me know if you would prefer I did it differently, Thanks.:
    Last edited by ezcapper; 22nd Oct 2014 at 22:01. Reason: both zip files were packaged wrong, too many sub folders
  6. New alpha version supports Drag and Drop input files, changing audio bitrate, tuning, and manually typing in additional commands. Please let me know of bugs, thank you.
    64-bit:
    https://drive.google.com/file/d/0B695hmOChptNaUJHZ1J6M01uZHc/view?usp=sharing
    32-bit:
    https://drive.google.com/file/d/0B695hmOChptNQVlTNVVpS1hVb1E/view?usp=sharing
    current version:
    The full version will be finished soon, with the ability to enable and disable 70 additional commands.
    Last edited by ezcapper; 27th Oct 2014 at 18:51. Reason: new Alpha version. Haven't checked for bugs though
  7. This is the last new post I'll put up on this topic for atleast a couple months. The full version is ready, it has 50 commands you can add through checkboxes etc under the more button. Supports Drag and Drop.
    64bit
    https://drive.google.com/file/d/0B695hmOChptNY3lJU0NGN1pUTDQ/view?usp=sharing
    32bit
    https://drive.google.com/file/d/0B695hmOChptNMlVIckhMS2x1eWc/view?usp=sharing
    Current Version
    Let me know if there are any bugs, I'll fix them asap.
    The 64 bit version uses x265 v1.3+55-c21ddfe6a6d9e234
    note: There is a small typo mistake in the GUI. To resume a paused recording, hit enter, not pause.
  8. ezcapper
    Thank you for your work available for testing.
    I will download and put to run.
  9. Great simple encoder...
    Can we get batch processing? I have several tv shows I would like to batch convert.
    EDIT. Actually looks like you have it set up to generate batch files so it wouldn't be hard to add.
  10. cool, really appreciate you guys trying it out and the requests. I will put up a version with batch processing by the end of the month, let me know if there is anything else. If I can't get it to work, I'll post the source code, somebody smarter will be able to do it easily.
  11. Before I found your encoder I tried handbrake, hybrid, several encoders and internet friendly media encoder http://ifme.sourceforge.net/.
    Please take a look at the interface its pretty simple and easy to use.
    Too bad its buggy and crashes frequently, probably from the audio conversion or the muxing I guess.
    Some questions:
    How is interlacing handled?
    How are subtitles handled?
    So the first track of the audio track is being passed through?
    Thanks again
  12. Originally Posted by adeoetrege View Post
    Some questions:
    Thanks again
    Thanks for the reply but I do not know the answer to your questions, but I assume the first track is passed through. I think it does not deinterlace. I will just post the source code in a couple days, it is in autohotkey and somebody will probably make all the improvements you want. This was the first time I ever did a GUI. I do not know anything about programming. I am unclear on the bugs comment. Are there many bugs in this GUI or in the others? I really apologize for not making the fixes myself, but autohotkey is a very simple language, I'm sure someone else will do it.
  13. I might have been doing something wrong, but out of 3 GUI's I've tried, YAX265 was the only one that worked. So thank you, ezcapper, for making this great GUI. Any chance you might release a new version with batch processing and updated x265 (and other stuff that I don't understand)?
  14. I am happy that it is useful to you. I'm having eyesight problems so no more development, but want other people to do it for me. I have also forgotten most of the programming language. It is open source and written in autohotkey. The source code is attached to this post. The source must be compiled in the same folder that the current gui is in to work properly. If I remember correctly I had begun adding batch encoding, it was very easy to do, when a hard drive crashed and I stopped working on it. Thanks to autokey forum, they got the source code out of the exe file and someone who is better with computers than me should be able to add batch encoding without too much difficulty.
    since it creates a bat file, to add batch encoding, First add a batch encoding button. Then just have a 2nd, 3rd, etc. drag and drop file add text to the bat file. Copy and paste that into the select input file button and you're done! Someone very good at autohotkey should be able to add that to the program and rerelease it in an hour's worth of work once figuring out how the source is written.
    preview of source code (preview seems to have line carriage mistakes and might not work. Please download attached file and make ahk file in noteplad to change program and compile):
    #SingleInstance force
    Gui, 2:+AlwaysOnTop
    Begin:
    MyNameIs = 0
    FileRead, First, Settings.txt
    FileRead, Fourth, Settings4.txt
    Gui, Add, Text,, BASIC OPTIONS:
    Gui, Add, Text,, Adjust the Speed Preset
    Gui, Add, DropDownList, vSpeeder, medium||slow|fast|slower|faster|veryslow|superfast|ultrafast
    Gui, Add, Text,,  Enter CRF Quality Value (0-51) OR Bitrate (52-52000) in kbps
    Gui, Add, Edit, w50 vBitrate, %First%
    Gui, Add, Text,, What Audio Quality Do You Want (kbps)?
    Gui, Add, DropDownList, vAudioQuality, Same||64|96|112|128|160|192|256|320|None
    Gui, Add, Text,, Tuning (Not necessary. For Advanced Users)
    Gui, Add, DropDownList, AltSubmit vTuning, none||psnr|ssim|zero-latency
    Gui, Add, Text,, Experimental: Additonal Parameters MUST USE THE FORMAT STYLE BELOW
    Gui, Add, Text,, EXAMPLE aq-strength=3:open-gop=0:keyint=250:crop-rect=top:early-skip=1
    Gui, Add, Edit, w500 vParam, %Fourth%
    Gui, Add, Text,, You can name your converted file if you want (don't type an extension)
    Gui, Add, Edit, w500 vName
    Gui, Add, Button, ys, INPUT_FILE
    Gui, Add, Text,, or Drag and Drop file
    Gui, Add, Button, Default, START
    Gui, Add, Text,,  Optional:
    Gui, Add, Button,, Storage_Folder
    Gui, Add, Button,, More
    Gui 2:Add, Checkbox, Checked vWpp, wpp
    Gui 2: Add, Text,, ctu
    Gui 2: Add, DropDownList, vCtu, 16|32|64||
    Gui 2: Add, Text,, tu-intra-depth
    Gui 2: Add, DropDownList, vTuintra, 1||2|3|4
    Gui 2: Add, Text,, tu-inter-depth
    Gui 2: Add, DropDownList, vTuinter, 1||2|3|4
    Gui 2: Add, Text,, me
    Gui 2: Add, DropDownList, AltSubmit vMe, dia|hex||umh|star|full
    Gui 2: Add, Text,, subme
    Gui 2: Add, Edit, w50 vSubme, 2
    Gui 2: Add, Text,, merange
    Gui 2: Add, Edit, w50 vMerange, 57
    Gui 2: Add, Checkbox, Checked vRect, rect
    Gui 2: Add, Checkbox, Checked vAmp, amp
    Gui 2: Add, Text,, maxmerge
    Gui 2: Add, Edit, w50 vMaxmerge, 2
    Gui 2: Add, Checkbox, vEarlyskip, early-skip
    Gui 2: Add, Checkbox, w150 vfastcbf, fast-cbf
    Gui 2: Add, Text,, RD-penalty
    Gui 2: Add, DropDownList, AltSubmit vRdPenalty, Disabled||RD-penalty|maximum
    Gui 2: Add, Checkbox, vTskip, tskip
    Gui 2: Add, Checkbox, vTskipfast, tskip-fast
    Gui 2: Add, Checkbox, Checked vStrongintrasmoothing, strong-intra-smoothing
    Gui 2: Add, Checkbox, vConstrainedintrasmoothing, constrained-intra
    Gui 2: Add, Checkbox, Checked vOpengop, open-gop
    Gui 2: Add, Text,, Keyint
    Gui 2: Add, Edit, w50 vKeyint, 250
    Gui 2: Add, Text,, min-keyint
    Gui 2: Add, Edit, w50 vMinkeyint, 0
    Gui 2: Add, Text, ys, scenecut
    Gui 2: Add, Edit, w50 vScenecut, 40
    Gui 2: Add, Checkbox, vNoscenecut, no-scenecut
    Gui 2: Add, Text,, rc-lookahead
    Gui 2: Add, Edit, w50 vRclook, 20
    Gui 2: Add, Text,, b-adapt
    Gui 2: Add, DropDownList, AltSubmit vBadapt, none|fast|full (trellis)||
    Gui 2: Add, Text,, bframes
    Gui 2: Add, Edit, w50 vbframe, 4
    Gui 2: Add, Text,, bframe-bias
    Gui 2: Add, Edit, w50 vbframebias, 0
    Gui 2: Add, Text,, b-pyramid
    Gui 2: Add, DropDownList, AltSubmit vBpyramid, Disabled|Enabled||
    Gui 2: Add, Text,, ref
    Gui 2: Add, Edit, w25 vRef, 3
    Gui 2: Add, Checkbox, Checked vWeightp, weight-p
    Gui 2: Add, Text,, vbv-bufsize
    Gui 2: Add, Edit, w50 vVbvbufsize, 0
    Gui 2: Add, Text,, vbv-maxrate
    Gui 2: Add, Edit, w50 vVbvmaxrate, 0
    Gui 2: Add, Text,, vbv-initial
    Gui 2: Add, Edit, w25 vVbvinitial, 0.9
    Gui 2: Add, Text,, qp
    Gui 2: Add, Edit, w25 vQp, 32
    Gui 2: Add, Text,, aq-mode
    Gui 2: Add, DropDownList, AltSubmit vAqmode, no Aq|aqVariance||AutoVariance|
    Gui 2: Add, Text,, aq-strength
    Gui 2: Add, Edit, w25 vAqstrength, 1.0
    Gui 2: Add, Text, ys, cbqpoffs
    Gui 2: Add, Edit, w25 vCbqp, 0
    Gui 2: Add, Text,, crqpoffs
    Gui 2: Add, Edit, w25 vCrq, 0
    Gui 2: Add, Text,, rd
    Gui 2: Add, Edit, w25 vRd, 3
    Gui 2: Add, Checkbox, Checked vSignhide, signhide
    Gui 2: Add, Checkbox, Checked vLft, lft
    Gui 2: Add, Checkbox, Checked vSao, sao
    Gui 2: Add, Checkbox, vSaolcubounds, sao-lcu-bounds
    Gui 2: Add, Checkbox, Checked vSaolcuopt, sao-lcu-opt
    Gui 2: Add, Checkbox, vSsim, ssim
    Gui 2: Add, Checkbox, vPsnr, psnr
    Gui 2: Add, Text,, hash
    Gui 2: Add, DropDownList, AltSubmit vHash, Disabled||MD5|CRC|Checksum|
    Gui 2: Add, Checkbox, vVui, vui
    Gui 2: Add, Text,, sar number (0-16)
    Gui 2: Add, Edit, w25 vSar, 0
    Gui 2: Add, Text,, overscan
    Gui 2: Add, DropDownList, vOverscan, undef||show|crop
    Gui 2: Add, Text,, videoformat
    Gui 2: Add, DropDownList, AltSubmit vVideoFormat, Undefined|component|pal|ntsc|secam|mac||
    Gui 2: Add, Checkbox, vRange, range (full if checked)
    Gui 2: Add, Text,, colorprim
    Gui 2: Add, DropDownList, vColorprim, bt709|bt470|bt470bg|smpte170m|smpte240m|film|bt2020|undef||
    Gui 2: Add, Text,, transfer
    Gui 2: Add, DropDownList, vTransfer, bt709bt709|bt470m|bt470bg|smpte170m|smpte240m|linear|log100|log316|iec61966-2-4|bt1361e|iec61966-2-1|bt2020-10|bt2020-12|undef||
    Gui 2: Add, Text,, colormatrix
    Gui 2: Add, DropDownList, vColormatrix, bt709|fcc|bt470bg|smpte170m|smpte240m|GBR|YCgCo|bt2020nc|bt2020c|undef||
    Gui 2: Add, Text, ys, chromalocs
    Gui 2: Add, Edit, w25 vChromalocs, 0
    Gui 2: Add, Checkbox, vFramefieldinfo, framefieldinfo
    Gui 2: Add, Text,, crop-rect
    Gui 2: Add, DropDownList, vCroprect, none||left|top|right|bottom
    Gui 2: Add, Checkbox, vTiminginfo, timinginfo
    Gui 2: Add, Checkbox, vFieldseq, fieldseq (future x265 feature)
    Gui 2: Add, Checkbox, vNalhrd, nal-hrd (future x265 feature)
    Gui 2: Add, Checkbox, vBitstreamr, bitstreamrestriction (future x265 feature)
    Gui 2: Add, Checkbox, vSubpichrd, subpichrd (future x265 feature)
    Gui 2: Add, Picture, w250 h-1, yak.jpg
    Gui 2: Add, Text,, Created by Vikram Valia
    Gui 2: Add, Text,, 10/27/2014
    Begin2:
    Gui Show
    Return
    GuiDropFiles:
    if A_EventInfo = 1
    MyNameIs = %A_GuiEvent%
    Choicer = %MyNameIs%
    FileDelete, Settings3.txt
    FileAppend, %MyNameIs%, Settings3.txt
    Splitpath, MyNameIs, MsgName
    Msgbox,,, Press Start to Convert %MsgName% , 2
    Return
    Now:
    FileDelete, Settings2.txt
    FileAppend, %Choice2%, Settings2.txt
    Return
    Now2:
    ButtonStorage_Folder:
    FileRead, Choice3, Settings2.txt
    FileSelectFolder, Choice2, *%Choice3%, 3, Choose a folder to Save the File in
    if Choice2=
    goto, Endtime
    else
    goto, Now
    ButtonMore:
    Gui, 2:Show
    goto, Begin2
    ButtonINPUT_FILE:
    FileSelectFile, Choice,3,, Select Video File to Convert
    if Choice=
    goto, Endtime
    else
    FileAppend, %Choice%, Settings3.txt
    goto, Begin2
    2GuiClose:
    Extra = 1
    Gui, 2:Submit
    Return
    ButtonSTART:
    Gui Submit
    FileRead, Choicer, Settings3.txt
    if Choicer=
    msgbox, Please Select Input File
    goto, Begin2
    QBfile:
    StringTrimLeft, Var7, A_WorkingDir, 2
    FileDelete, x2652.bat
    If Bitrate < 52
    goto, CRF
    else
    goto, Brtime
    Brtime:
    FileRead, Prog, x265.bat
    StringReplace, Var2, Prog, crf=28, bitrate=%Bitrate%, 1
    goto, AudioQualityTime
    CRF:
    StringReplace, Var2, Prog, crf=28, crf=%Bitrate%, 1
    AudioQualityTime:
    if AudioQuality = Same
    goto, TuningTime
    if AudioQuality = None
    goto, NoAudioTime
    else
    StringReplace VarAudio1, Var2, -c:a copy, -c:a libvo_aacenc -b:a %AudioQuality%000
    Var2 = %VarAudio1%
    goto, TuningTime
    NoAudioTime:
    StringReplace VarAudio1, Var2, -c:a copy, -c:a copy -an
    Var2 = %VarAudio1%
    goto, TuningTime
    TuningTime:
    if Tuning = 1
    goto, ParamTime
    else
    goto, BTuningTime
    BTuningTime:
    if Tuning = 4
    StringReplace VarTuning, Var2, 20p -, 20p -tune zero-latency -
    Var2 = %VarTuning%
    goto, ParamTime
    if Tuning = 3
    StringReplace VarTuning, Var2, 20p -, 20p -tune ssim -
    Var2 = %VarTuning%
    goto, ParamTime
    if Tuning = 2
    StringReplace VarTuning, Var2, 20p -, 20p -tune psnr -
    Var2 = %VarTuning%
    goto, ParamTime
    ParamTime:
    if Param =
    goto, RestofFileTime
    StringReplace VarPar, Var2, : -, :%Param%: -
    Var2 = %VarPar%
    RestofFileTime:
    If MyNameIs = 0
    goto PartB
    PartA:
    PartB:
    StringReplace, Var3, Var2, in.mov, "%Choicer%", 1
    StringReplace, Var4, Var3, cd\, cd%Var7%
    StringReplace, Var5, Var4, -preset medium, -preset %Speeder%
    Splitpath, Choicer,,,, Namer
    If Name =
    goto, Next
    else
    goto, Next2
    Next:
    if Bitrate < 52
    StringReplace, Var6, Var5, out.mkv, "%Choice3%\%Namer%Q%Bitrate%.mkv"
    else
    StringReplace, Var6, Var5, out.mkv, "%Choice3%\%Namer%B%Bitrate%.mkv"
    FileAppend, %Var6%, x2652.bat
    If Extra = 1
    goto, MessingAround
    else
    goto, Starttime
    Next2:
    StringReplace, Var6, Var5, out.mkv, "%Choice3%\%Name%.mkv"
    If Extra = 1
    goto, MessingAround
    else
    goto, Starttime
    Starttime:
    FileDelete, Settings4.txt
    FileAppend, %Param%, Settings4.txt
    FileDelete, Settings.txt
    FileAppend, %Bitrate%, Settings.txt
    FileRead, Showtime, x2652.bat
    Almost:
    if Showtime =
    Sleep, 500
    goto, Almost
    Done:
    Run, x2652.bat
    Msgbox, 4096, Pause/Resume, The Pause Key - Pause /  Enter - Resume /  Ctrl+C - Stop / Black Screen Closes - You're Done!, 5
    ExitApp
    Endtime:
    ExitApp
    ExitApp
    GuiClose:
    ExitApp
    MessingAround:
    if Wpp = 0
    FileRead, Prog2, x2652.bat
    StringReplace, VarWpp, Prog2, : -, :wpp=0: -, 1
    else
    VarWpp = %Prog2%
    if Ctu <> 64
    StringReplace, VarCtu, VarWpp, : -, :ctu=%Ctu%: -, 1
    else
    VarCtu = %VarWpp%
    if Tuintra <> 1
    StringReplace, VarTuintra, VarCtu, : -, :tu-intra-depth=%Tuintra%: -, 1
    else
    VarTuintra = %VarCtu%
    if Tuinter <> 1
    StringReplace, VarTuinter, VarTuintra, : -, :tu-inter-depth=%Tuinter%: -, 1
    else
    VarTuinter = %VarTuintra%
    if Me <> 2
    Me := Me - 1
    StringReplace, VarMe, VarTuinter, : -, :me=%Me%: -, 1
    else
    VarMe = %VarTuinter%
    if Subme <> 2
    StringReplace, VarSubme, VarMe, : -, :subme=%Subme%: -, 1
    else
    VarSubme = %VarMe%
    if Merange <> 57
    StringReplace, VarMerange, VarSubme, : -, :merange=%Merange%: -, 1
    else
    VarMerange = %VarSubme%
    if Rect = 0
    StringReplace, VarRect, VarMerange, : -, :rect=0: -, 1
    else
    VarRect = %VarMerange%
    if Amp = 0
    StringReplace, VarAmp, VarRect, : -, :amp=0: -, 1
    else
    VarAmp = %VarRect%
    if Maxmerge <> 2
    StringReplace, VarMaxmerge, VarAmp, : -, :max-merge=%Maxmerge%: -, 1
    else
    VarMaxmerge = %VarAmp%
    if Earlyskip = 1
    StringReplace, VarEarlyskip, VarMaxmerge, : -, :early-skip=1: -, 1
    else
    VarEarlyskip = %VarMaxmerge%
    if fastcbf = 1
    StringReplace, Varfastcbf, VarEarlyskip, : -, :fast-cbf=1: -, 1
    else
    Varfastcbf = %VarEarlyskip%
    if RdPenalty <> 1
    RdPenalty := RdPenalty - 1
    StringReplace, VarRdPenalty, Varfastcbf, : -, :rdpenalty=%rdpenalty%: -, 1
    else
    VarRdPenalty = %Varfastcbf%
    if Tskip = 1
    StringReplace, VarTskip, VarRdPenalty, : -, :tskip=1: -, 1
    else
    VarTskip = %VarRdPenalty%
    VarFinal = %VarTskip%
    if Tskipfast = 1
    StringReplace, VarFinal2, VarFinal, : -, :tskip-fast=1: -, 1
    VarFinal = %VarFinal2%
    if Strongintrasmoothing = 0
    StringReplace, VarFinal2, VarFinal, : -, :strong-intra-smoothing=0: -, 1
    if Constrainedintrasmoothing = 1
    StringReplace, VarFinal2, VarFinal, : -, :constrained-intra=1: -, 1
    if Opengop = 0
    StringReplace, VarFinal2, VarFinal, : -, :open-gop=0: -, 1
    if Keyint <> 250
    StringReplace, VarFinal2, VarFinal, : -, :keyint=%Keyint%: -, 1
    if Minkeyint <> 0
    StringReplace, VarFinal2, VarFinal, : -, :min-keyint=%Minkeyint%: -, 1
    if Scenecut <> 40
    StringReplace, VarFinal2, VarFinal, : -, :scenecut=%Scenecut%: -, 1
    if Noscenecut = 1
    StringReplace, VarFinal2, VarFinal, : -, :no-scenecut=1: -, 1
    if Rclook <> 20
    StringReplace, VarFinal2, VarFinal, : -, :rc-lookahead=%Rclook%: -, 1
    If Badapt <> 3
    Badapt := Badapt - 1
    StringReplace, VarFinal2, VarFinal, : -, :b-adapt=%Badapt%: -, 1
    if bframebias <> 0
    StringReplace, VarFinal2, VarFinal, : -, :bframe-bias=%bframebias%: -, 1
    if bframe <> 4
    StringReplace, VarFinal2, VarFinal, : -, :bframes=%bframe%: -, 1
    if Bpyramid = 1
    StringReplace, VarFinal2, VarFinal, : -, :b-pyramid=0: -, 1
    if Ref <> 3
    StringReplace, VarFinal2, VarFinal, : -, :ref=%Ref%: -, 1
    if Weightp = 0
    StringReplace, VarFinal2, VarFinal, : -, :weightp=0: -, 1
    if Vbvbufsize <> 0
    StringReplace, VarFinal2, VarFinal, : -, :vbv-bufsize=%Vbvbufsize%: -, 1
    if Vbvmaxrate <> 0
    StringReplace, VarFinal2, VarFinal, : -, :vbv-maxrate=%Vbvmaxrate%: -, 1
    if Vbvinitial <> 0.9
    StringReplace, VarFinal2, VarFinal, : -, :vbv-init=%Vbvinitial%: -, 1
    if QP <> 32
    StringReplace, VarFinal2, VarFinal, : -, :qp=%QP%: -, 1
    if Aqmode <> 2
    Aqmode := Aqmode - 1
    StringReplace, VarFinal2, VarFinal, : -, :aq-mode=%Aqmode%: -, 1
    if Aqstrength <> 1.0
    StringReplace, VarFinal2, VarFinal, : -, :aq-strength=%Aqstrength%: -, 1
    if Cbqp <> 0
    StringReplace, VarFinal2, VarFinal, : -, :cbqpoffs=%Cbqp%: -, 1
    if Crq <> 0
    StringReplace, VarFinal2, VarFinal, : -, :crqpoffs=%Crq%: -, 1
    if Rd <> 3
    StringReplace, VarFinal2, VarFinal, : -, :rd=%Rd%: -, 1
    if signhide = 0
    StringReplace, VarFinal2, VarFinal, : -, :signhide=0: -, 1
    if lft = 0
    StringReplace, VarFinal2, VarFinal, : -, :lft=0: -, 1
    if Sao = 0
    StringReplace, VarFinal2, VarFinal, : -, :sao=0: -, 1
    if Saolcubounds = 1
    StringReplace, VarFinal2, VarFinal, : -, :sao-lcu-bounds=1: -, 1
    if Saolcuopt = 0
    StringReplace, VarFinal2, VarFinal, : -, :sao-lcu-opt=0: -, 1
    if Ssim = 1
    StringReplace, VarFinal2, VarFinal, : -, :ssim=1: -, 1
    if Psnr = 1
    StringReplace, VarFinal2, VarFinal, : -, :psnr=1: -, 1
    if Hash <> 1
    Hash := Hash - 1
    StringReplace, VarFinal2, VarFinal, : -, :hash=%Hash%: -, 1
    if Vui = 1
    StringReplace, VarFinal2, VarFinal, : -, :vui=1: -, 1
    if Sar <> 0
    StringReplace, VarFinal2, VarFinal, : -, :sar=%Sar%: -, 1
    if Overscan <> undef
    StringReplace, VarFinal2, VarFinal, : -, :overscan=%Overscan%: -, 1
    if Videoformat <> 6
    Videoformat := Videoformat - 1
    StringReplace, VarFinal2, VarFinal, : -, :videoformat=%Videoformat%: -, 1
    if Range = 1
    StringReplace, VarFinal2, VarFinal, : -, :range=full: -, 1
    if Colorprim <> undef
    StringReplace, VarFinal2, VarFinal, : -, :colorprim=%Colorprim%: -, 1
    if Transfer <> undef
    StringReplace, VarFinal2, VarFinal, : -, :transfer=%Transfer%: -, 1
    if Colormatrix <> undef
    StringReplace, VarFinal2, VarFinal, : -, :colormatrix=%Colormatrix%: -, 1
    if Chromalocs <> 0
    StringReplace, VarFinal2, VarFinal, : -, :chromalocs=%Chromalocs%: -, 1
    if Framefieldinfo = 1
    StringReplace, VarFinal2, VarFinal, : -, :framefieldinfo=1: -, 1
    if Croprect <> none
    StringReplace, VarFinal2, VarFinal, : -, :crop-rect=%Croprect%: -, 1
    if Timinginfo = 1
    StringReplace, VarFinal2, VarFinal, : -, :timinginfo=1: -, 1
    if Fieldseq = 1
    StringReplace, VarFinal2, VarFinal, : -, :fieldseq=1: -, 1
    if Nalhrd = 1
    StringReplace, VarFinal2, VarFinal, : -, :nalhrd=1: -, 1
    if Bitstreamr = 1
    StringReplace, VarFinal2, VarFinal, : -, :bitstreamrestriction=1: -, 1
    if Subpichrd = 1
    StringReplace, VarFinal2, VarFinal, : -, :subpichrd=1: -, 1
    FileAppend, %VarFinal%, x2652.bat
    goto, Starttime
  15. Hello everyone.
    Maybe someone backup the last version of the Yet Another X265 GUI (Yax265Gui)? All links died. Please, upload somewhere (for example at Google drive). Thank you in advance.
  16. DECEASED
    Jun 2009
    Heaven
    Originally Posted by Fedor Korkunov View Post
    Hello everyone.
    x265 itself has changed a lot since 2015. So if you really need a GUI for x265, you'd better look for something else, because the old GUIs were designed for outdated versions of x265.
    "Programmers are human-shaped machines that transform alcohol into bugs."
