Hi all the cats,
in my dinosaurus In sync speed razor 5.51 professional NLE
when I press the dot "." in the numpad happen that the nle go to play, and some others function when I press the "6" or "4" key of the numpad and others key in the keyboard.
It seems that when I load the program, it use a special keys. I don't wont is, I would like use the numpad standard.
In windows 8.1 32bit I have not the problem.
I don't know if the guily is of the EDIUS 7.2 installation or not.
I wonder: is there a way to "reset" in windows 8.1 the special keys for a specific program? thanks
