Results 1 to 24 of 24
  1. Member blinky88's Avatar
    Mar 2004
    Australia
    Hoping a member may be able to help me converting flac files to MP3. I have downloaded SmartFFmpeg however it will not start-up.
    Cheers from downunder.
  2. Avanti or WinFF are more commonly used ffmpeg guis. I can personally attest that they both start.
  3. TAudioConverter is designed for converting audio.
    I'll also give foobar2000 a recommendation but it'll probably take more time to set it up and get used to it. I think you need to download the LAME MP3 encoder yourself and foobar2000 will ask you where it is the first time you try to encode an MP3.
    The main reason I use foobar2000 a lot for audio encoding (I also use it to re-encode movie soundtrack audio etc to AAC) is because once you have the converter presets you require set up and saved, conversion is very easy. You can load as many audio tracks as you like into a playlist, highlight them all, right click and select convert, and foobar2000 will convert as many simultaneously as you have CPU cores until it's done.
  4. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    Westernmost point of Europe
    I strongly recommend foobar2000. It may not be the easiest choice around, but it's well worth the initial effort.
    "The greatest trick the Devil ever pulled was convincing the world he didn't exist."
    Jan 2005
    Do you mean music files?
    If not foobar, there's LameDropXPd. Very simple, just drag-n-drop your flacs to get Lame v.3.99.5 encoded mp3s. Right click the window to check/change any settings (like output directory, VBR quality, etc), then you're all set.
    32 & 64 bit versions available
    http://www.rarewares.org/mp3-lamedrop.php
    I want NBC's Ed on DVD/Blu-ray!
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    As opposed to what ?
    Video ?
    FLAC, Free Lossless Audio Codec.
    Yeah, I would say it's a good bet they are music files, not that it really matters as it could be a lecture or any audio, but FLAC is AUDIO.
    Jan 2005
    I know what flac is. I was just asking because I wasn't sure Lamedrop would take something as long as a movie's/concert's audio track. I guess it probably does, though.
  8. Banned
    Jun 2004
    I don't know about lamedrop but you asked if he meant "music files", like it matters, FLAC is audio regardless.......
    canada
    Audacity is a good program to convert flac to mp3 as long as you install the lame_enc.dll into audacity for mp3 output.
  10. Originally Posted by redsandvb View Post
    Huh? What's does that have to do with what was originally asked?
    No one has mentioned anything about duration (apart from you).
  11. I'm a Super Moderator johns0's Avatar
    canada
    Don't click on his link since it's an unknown file,i only trust most forum links here.
  12. Originally Posted by johns0 View Post
    Whose link?
  13. I'm a Super Moderator johns0's Avatar
    canada
    redsandvb links.
  14. Originally Posted by johns0 View Post
    redsandvb links.
    VideoHelp links to Rarewares site as well (i.e. Visit developers site).
    Stop worrying.
  15. Originally Posted by johns0 View Post
    That implies there's some you don't trust
  16. I'm a Super Moderator johns0's Avatar
    canada
    Such as crappy k-lite links.
    Jan 2005
    Not much, but in the off chance that the OP actually wanted to convert a concert/movie track I didn't want to recommend Lamedrop if it didn't work with long tracks. That's all
    You don't have to trust my link if you don't want to. Going to rarewares.org one could navigate to the mp3 section, then to the Lamedrop section on their own. Sure it doesn't say anything about the actual file itself but you can look at the source code if you want, it's there to download as well. BTW, I am not the developer. I just use rarewares to get my lame and flac compiles and a few other things. About Lamedrop, it's just a nice easy way for someone to convert to lame encoded mp3s...especially for people unfamiliar with foobar, etc. Just trying to be helpful.
  18. Rarewares use most of the guys from Hydrogenaudio. It is a trusted site. Also, lamedropXPd works just fine. you can access more options by right-clicking on drop window.
  19. Originally Posted by Noahtuck View Post
    Video ?
    At the risk of being argumentative.....
    FLAC can be multi-channel, but MP3 can't (I know there's a version which can be but for the sake of the discussion it's not relevant). It's more liley FLAC music files won't be multichannel and require a conversion program capable of down-mixing.
  20. If you don't mind the extra step of decoding the FLAC files to WAV, then try Trader's Little Helper. Then RazorLame to encode wav to mp3.
    Darryl
    Jun 2005
    Vermont
    OR you could do it the easy way with Freemake Audio Converter.
  22. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    It's 2014, and we need a thread on how to encode MP3 at this point? Like, it's a challenge or problem?
    I hate VHS. I always did.
  23. Banned
    Jun 2004
    Video ?
    DON'T get me going!!!!!!
    I have been being pretty good for a while now!!!
    LOL!!
