Results 1 to 10 of 10
    Jul 2014
    Purcellville, VA
    Hello everyone, my name is Mark and I am new to the forums. Anyways, I have a few clips that are shot with the Canon T2i and I didn't realize that there was a lens flare on some of them when I was shooting. So as a result I have lens flares on some of them, is there anyway to remove that? I have Sony Movie Studio Platinum 12.
    Thanks,
    Mark
  2. Unless you are dealing with static shots it is very, very difficult in general. You have to both track the flare and replace it with something convincing. Movie Studio is technically capable, but a lot depends on your image. Please post a sample if you want more specific advice.
  3. Just pretend you're J.J Abrams
  4. Originally Posted by poisondeathray View Post
    Yes, and Vegas Movie Studio can certainly add shake.
    Jul 2014
    Purcellville, VA
    I don't really think that I'll bother then, the lens flare is on the subject so it sounds like it would be pretty hard. Thanks for the help though, appreciate the time.
    Mark
  6. Originally Posted by Necer149 View Post
    Mark
    That may be the most sensible posting I've ever read from a new member. Welcome to the forums.
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Good one! If a viable solution is ever found please send it to JJ
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
  8. If the flare presents itself as a closed shape and not moving around too much, it may be possible to use AviUtl (mtDeSub plugin) or AviSynth (InpaintFunc) to fill-in that area. (These are actually functions for logo removal)
    I don't have MovieStudio so I can't tell if it has analogous functions
    Jul 2014
    Purcellville, VA
    The lens flare is a closed shape and is pretty small. Also, my DSLR is on a tripod and I never do any pans or zooms in the shot so I'll try it out. Thanks for the suggestion!
    Mark
  10. Originally Posted by Necer149 View Post
    It also matters if the subject matter is moving behind the flare.
