Results 1 to 25 of 25
    Dec 2008
    Switzerland
    Hi,
    I've managed to extract the subtitles for a TV show from my Sat Box.
    The subtitles are bunch of .png files.
    Around 300 files for each episode.
    The timing for those .png files is in the below format:
    <I s="10.510" e="13.320" x="276" y="472" w="202" h="46" i="AYZ-4.png" />
    <I s="13.490" e="16.490" x="244" y="469" w="266" h="42" i="AYZ-5.png" />
    <I s="849.940" e="853.430" x="208" y="403" w="340" h="115" i="AYZ-206.png" />
    I know that BDN (XML + PNG) subtitle format can be converted easily to idx/sub, but as you can see the timing format is seconds and milliseconds not like the usual timing format in BDN subtitles XML files which is HH:MM:SS:FF
    Any ideas or suggestions how I can convert those extracted subtitles into idx/sub format.
    Kind Regards,
    Mouna.
  2. So, the only problem is the way the times are formated the rest would be fine?
    (converting seconds -> hh:mms:ff doesn't sound so hard)
    users currently on my ignore list: deadrats, Stears555
    Dec 2008
    Switzerland
    Yes. I think I can take an existing valid XML subtitle file and replace the names of the images with the new images that I've got.
    The issue now will be to convert seconds to hh:mms:ff
    How this can be done in a systematic way.
    Kind Regards,
    Mouna.
  4. Wrote a small quick&dirty console tool to convert such e="time in seconds" to e="hh:mm:ss:ff".
    Attached source code and 64bit Windows binary.
    What the program does is:
    1. read a file
    2. split it's content into lines
    3. check if line contains 'e="..."'
    4. convert the '...' from text to number
    5. convert the number to hh:mm:ss:ff
    6. replace '...' with the new 'hh:mm:ss:ff'
    7. save the file under a new name (= old name + _adjusted)
    Cu Selur
    Dec 2008
    Switzerland
    1. read a file
    Cu Selur
    Thanks for your great help Selur.
    The timing in my file has two parts.
    Start of timing, s="
    and
    End of timing, e="
    you covered both or just the end?
    Kind Regards,
    Mouna.
  6. just the end, gimme a second
  7. attached a new version which should replace both e="..." and s="..." (didn't test it, but it should work)
    Dec 2008
    Switzerland
    Thanks again Selur,
    It seems that the Start is still not included as shown in the below screenshot.
    Also, the resulting output file is empty.
    I've included both original file that has my timing and output file for your convenience, if you could take a look at them.
    I have another question regarding preparing the XML file.
    Appreciate if you or any generous member who has experience in those kind of issue would be kind to help me.
    The format of XML file should be as follow:
    <?xml version="1.0" encoding="UTF-8"?>
    <BDN Version="0.93" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="BD-03-006-0093b BDN File Format.xsd">
      <Description>
        <Name Title="Test._track3_eng_exp_exp" Content=""/>
        <Language Code="eng"/>
        <Format VideoFormat="1080p" FrameRate="23.976" DropFrame="False"/>
        <Events Type="Graphic" FirstEventInTC="00:01:01:22" LastEventOutTC="01:31:16:05" NumberofEvents="722"/>
      </Description>
      <Events>
        <Event InTC="00:01:01:22" OutTC="00:01:04:00" Forced="False">
          <Graphic Width="419" Height="59" X="750" Y="860">Test_0001.png</Graphic>
        </Event>
        <Event InTC="00:01:04:05" OutTC="00:01:05:17" Forced="False">
          <Graphic Width="255" Height="59" X="832" Y="860">Test_0002.png</Graphic>
        </Event>
    Now my file for the timing is as follow:
    					<text>&lt;TimedImages targetWidth="720" targetHeight="576" aspectRatio="16:9"&gt;
    &lt;I s="0.600" e="3.720" x="268" y="458" w="218" h="58" i="AYZ1.png" /&gt;
    &lt;I s="3.840" e="6.960" x="290" y="400" w="176" h="111" i="AYZ2.png" /&gt;
    Is there an easy way to automate the process of converting the timing file into XML file.
    Thanks & Regards,
    Mouna.
  9. Ah mistake on my side I looked for '" s="'
    is there an easy way to automate the process of converting the timing file into XML file.
    Don't know any tool which does the conversion, so you would have to write one. Shouldn't be hard if you know how to do some programming.
    All in all it would require to:
    a. convert the input to proper xml (remove html escaping)
    b. read the xml into a dom structure
    c. parse the dom structure
    d. create a new dom structure which looks like the one you want
    e. write the output to a file.
    Probably one or may be two hours of work, assuming the programming language used offers some xml helper tools. If one would want to do it with in a bash or dos script it would probably take quite some time.
    Cu Selur
    Ps.: may be BDSup2Sub++ supports the format your sat box uses. (sadly it's not actively developed anymore otherwise it should have been easy for the author to add support for it)
    Dec 2008
    Switzerland
    Ah mistake on my side I looked for '" s="' :)
    Cu Selur
    Thanks a lot for your help and support Selur :)
    Just one question regarding the time conversion.
    I noticed in some lines the time as follow:
    00:18:49:7
    00:19:54:3
    shouldn't there be 2 digits in the milliseconds part or it won't be a problem.
    Unfortunately, I don't have knowledge in programming, although I've studied Pascal Language in the University long long long time back :D
    Just to make it simple for anyone who has the capability to help, the requirement is only to convert each line in the attached file "test_f_adjusted.txt" to an equivalent line in XML.
    Below is an example:
    &lt;I s="00:00:00:60" e="00:00:03:72" x="268" y="458" w="218" h="58" i="AYZ1.png" /&gt;
    This should be converted to the below 3 lines:
        <Event InTC="00:00:00:60" OutTC="00:00:03:72" Forced="False">
          <Graphic Width="218" Height="58" X="268" Y="458">AYZ1.png</Graphic>
        </Event>
    Kind Regards,
    Mouna.
    Dec 2008
    Switzerland
    Hi,
    I did a lot of research and here is what I found.
    First, I've found the .XML file (attached) from my Sat Box.
    This XML file seems to be different than the XML file that is accepted by BDSup2Sub as shown in the below screen shot.
    It seems that BDSup2Sub accepts only Sony BDN XML files.
    As you can see from the comparison for the first few lines of each XML files (both attached as well) they are different.
      <Description>
        <Name Title="Test.1 - KRaLiMaRKo_track3_eng_exp_exp" Content=""/>
      </Description>
      <Events>
        </Event>
        </Event>
        <Event InTC="00:01:10:11" OutTC="00:01:12:09" Forced="False">
          <Graphic Width="662" Height="59" X="629" Y="860">Test_0003.png</Graphic>
        </Event>
    <TimedImages targetWidth="720" targetHeight="576" aspectRatio="16:9">
    <I s="0.600" e="3.720" x="268" y="458" w="218" h="58" i="AYZ-1.png" />
    <I s="3.840" e="6.960" x="290" y="400" w="176" h="111" i="AYZ-2.png" />
    <I s="7.080" e="10.440" x="238" y="458" w="278" h="58" i="AYZ-3.png" />
    Now I would like some help to figure out:
    1. Is there any program/utility capable to convert the attached XML + PNG files into idx/sub file.
    2. Is there any program/utility capable to convert the attached XML file into Sony BDN XML file which BDSup2Sub can accept.
    Appreciate any help.
    Kind Regards,
    Mouna.
    Jul 2011
    Denmark
    You could try Subtitle Edit 3.4... right click in the list view in the ocr window, and choose Export -> ...
  13. Attached a small tool for conversion AYZ.xml -> AYZ_adjusted.xml which should produce the needed output.
    Cu Selur
  14. just out of curiosity: did XMLConverter help?
    Dec 2008
    Switzerland
    Hi Selur,
    Sorry for the late reply.
    I tried the XML Converter and it seems that it will work, but it needs few modifications:
    1.
    This line:
    <xml version="1.0" encoding="UTF-8"/>
    Should be modified to be:
    I'm gussing it is like a standard thing for XML files.
    2.
    The VideoFormat should be changed from:
     <Format DropFrame="False" VideoFormat="576p" FrameRate="25"/>
    to:
     <Format DropFrame="False" VideoFormat="720p" FrameRate="25"/>
    3.
    You didn't include the PNG files in the converted file :)
    This line & similar lines:
     <Graphic Height="58" Width="218" X="268" Y="458"/>
    Should be:
     <Graphic Height="58" Width="218" X="268" Y="458">AYZ-1.png</Graphic>
    4.
    The order in the Graphic Line should be:
    I noticed that you have put Height before Width, I don't know if this will make an issue or not.
    5.
    Whenever I tried your tool the order is becoming like this:
    <Event Forced="False" InTC="00:00:21:80" OutTC="00:00:24:51">
       <Graphic X="208" Height="96" Y="415" Width="338"/>
    </Event>
    I don't know why this is happening, maybe I'm putting the command wrongfully.
    6.
    I didn't mention this before, but the PNG file is in the original XML file might be like below:
    i="Test/Test-1.png"
    Could the utility ignore the folder "Test" before the PNG file name, otherwise I have to create a folder with same name and put the XML + PNG files inside this folder.
    7.
    This is probably beyond the scope of the utililty, but I'm just mentioning as someone might help.
    I tried to fix those issues manually on the first few lines and then converted the XML + PNG files into idx/sub file.
    There are two issues:
    - Subtitles Size: they are smaller than usuall.
    - Subtitles Position: they were positioned above the middle of the left side of the screen.
    I tried to convert an existing idx/sub file to XML + PNG and then took the values of Width, Height, X and Y from the XML file and replaced the values in the generated XML file.
    This resulted for the subtitle size to increase a little bit and the subtitle position now became below the middle of the right side of the screen.
    I'm not sure what is the reason for this issue, I need to research a little bit regarding the values of Width, Height, X and Y in the XML file and their significant.
    Anyhow, thanks for your great help Selur.
    Kind Regards,
    Mouna.
  16. Code:
    will only be used if the resolution is 720x576, why would you specify 720p if you resolution isn't 1280x720?
    looking at the TimedImages info:
    the VideoFormat should be 576p
    About the order: xml documents normally have no order for their attributes -> order of attributes should not matter.
    About the image: Will fix that.
  17. attached a version which when called with:
    XMLConverter.exe "eng" "23.976" "720p" "PATH TO xml file"
    should:
    a. remove the path from the images
    b. set VideoFormat="720p"
    c. set FrameRate="23.976"
    d. set the header to:
    it does not reorder attributes, since XML does not require a specific order of attributes.
  18. Member
    Dec 2008
    Switzerland
    Hi Selur,
    Forgot to mention one more issue in few lines regarding the timing:
    The timing is transferred to:
     <Event InTC="00:00:07:8" OutTC="00:00:10:43" Forced="False">
    Is this going to caue an issue.
    Regards,
    Mouna.
  19. it might,.. will look into it
  20. should work now
    Dec 2008
    Switzerland
    should work now
    Working like charm now Selur
    Many thanks for your great help.
    I'm working now to resolve the issue of Subtitles Position & Size.
    Kind Regards,
    Mouna.
  22. my guess the problem is that the subtitles belong to SD content (according to your input xml) and you flag them as hd content.
    -> much luck
  23. Member
    Dec 2008
    Switzerland
    -> much luck
    You are right. It is an SD content indeed.
    What do you suggest to be done?
  24. Member
    Dec 2008
    Switzerland
    -> much luck
    Nevermind Selur. I just figured it out & changed the video format to "576i" and this resolved my subtitle size and position issue
    Again, I can't thank you enough for your great support.
    Kind Regards,
    Mouna.
  25. ah, 576i and not 576p like I guessed
