  1. Hi guys, I'm not sure if this is possible, but I have a copy of T2 Skynet Edition, and I've used it a few times for a quick calibration of TVs over the years. Rather than always using that disc (stop the wear and tear), I'd like to be able to just grab and burn that THX portion and make a new disc.
    Can anyone tell me how to go about finding this portion on a disc and ripping it? Preferably on the Mac. Thanx.
  2. rip (= copy while removing copy protection) the blu-ray to disk using MakeMKV (File-->Backup), then check which m2ts file inside the BDMV\STREAM folder contains the content you want
    users currently on my ignore list: deadrats, Stears555
  3. If you extract the THX Optimizer, you're gonna screw navigation, no? There will no longer be a menu structure (hence navigation) unless you re-create one. I admit, it's been a very long time since I used the THX Optimizer.
    Why not just download this and burn it to disc (it's free):
    http://www.avsforum.com/forum/139-display-calibration/948496-avs-hd-709-blu-ray-mp4-calibration.html
    [EDIT] And welcome to the forum.
    Pull! Bang! Darn!
  4. Clown_BD BD Copier 0.41 might work in this situation.
