Another Newbie here!! My DV444 will only play SVCD's of 2500 bitrate so on that note... when encoding I set the bitrate to 2500. I've tryed several tests playing with (TMPGEnc... sorry) the full screen, center (keep asp. rat.) things like that ... but just on like 3000 frames that way i dont have to wait for full rip and not get what i want. anyways..... how does that effect my final rip? T.I.A. P.S. what is the long term effect on my CPU... LOTS in LOTS of crunchin going on :o
Thread: bitrate 2520 vs 2500
Encoding a few thousand frames is fine and smart for testing the limits of your dvd player.
As long as your encoding computer is not a laptop, keep on truckin ... I mean encoding. Laptops have poor heat disipation and are expensive to replace the processor. Desktops processors are cheaply/easily replaced and I have never had a CPU burn up from constant use. Hard drives are another matter ... they will eventually die.
Thanks for your time bbb :o
not really sure that answerd the bitrate question...
I have a Pioneer 440 which is almost identical to a 444 (except it's black and has no pseudo-progressive output).
With my player, I have found that 2500 is the highest limit to use without occassional video glitches and blips. To be on the safe side, I've started using 2450 (audio bitrate 224) as the max to avoid stutters and wierd random artifacts.
Make 1 minute movies and see if there are any wierd video glitches at 2520, 2500, and 2450. If there are none, you can use that bitrate. However, include the audio to make sure that your player can handle the video+audio total bitrate. Once you have found the perfect maximum settings, save it as a template, write it down, or commit it to memory.
Hey bbb where do i set the audio bitrate?? or does it set it auto when i go to 2450? what would be the dif if i went 2420 (1000 less)?? T.I.A.
I just tried 2420... no good worse than 2500, any reason why you picked 2450?? is there any ryme or reason!! lol
Need BluRay player that does what Philips 2500/2700 does,but sells in USA
By ufcdave in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2011, 21:41 -
anyone know how to unlock denon dvd-2500 regions
By similar in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 14:03 -
I just bought an expensive laptop - was it a $2500 mistake?
By Eat Right in forum ComputerReplies: 35Last Post: 18th Nov 2009, 12:33 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
DVD shrink is only encoding @ 2500 KB/s or so? Instead of the 12000KB/s?
By Denvers Dawgs in forum DVD RippingReplies: 6Last Post: 29th Jun 2008, 10:23
