  1. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Hello, everybody!
    I have DVD full of yellow stains, I tried "MCTemporalDenoise()" and did a very awesome job in preview encoding, but I found it so slow and gave me about "1-2 fps" in the encoder, Is there is any other solution to get rid from these stains or at least decrease it? Here is the sample :
    Thanks in advance!
  2. Member Cornucopia's Avatar
    Sounds like your cat peed on it. I would use a detergent, with oxy-clean and an enzyme-based bio-cleaner.
  3. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    hahaha, nice one ), very funny. away from peeing, Can you tell another way instead of these chemicals, Thanks!
  4. Member Cornucopia's Avatar
    You do want a temporal or spatio-temporal denoiser. It could be your choice happened to be your best option. I wouldn't sweat the slow processing FPS. Just be glad it works as hoped.
  5. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Thank you, friend
