  1. Member blinky88's Avatar
    Mar 2004
    Australia
    Trying to add a printer and keep getting a message "the print spooler service is not running" really appreciate some help in solving this problem.
    Cheers from downunder.
    Feb 2004
    Australia
    Whats happening , lol
    Need to know what os is used, printer make, model, how its connected and driver version installed.
    If you have another user profile on the system log off from current account and log in via the other users account and see if this makes a change ... if not it generally rules out user profile corruption.
  3. DECEASED
    Jun 2009
    Heaven
    In this case at least, the error message means what it says. If that service is stopped or disabled, then you can't even access the printer(s) you already have installed.
  4. Member blinky88's Avatar
    Mar 2004
    Australia
    Problem solved, thank you to members who responded.
