Results 1 to 19 of 19
  1. I wonder if anyone has found some software that will allow me to convert TV Freeview HD m2ts files or will allow me to play these files from the computer
    All i get with the software i have tried so far is a failed to load come up
    thanks
  2. Could you tell us how you recorded them? HD is usually encrypted.
    Post a mediainfo report (View>Text) of one of the m2ts files.
    Tell us which softwares you tried (so we don't repeat suggesting something).
  3. Originally Posted by transporterfan View Post
    General
    Complete name : C:\00001.m2ts
    File size : 1.28 GiB
    this is the text view ?
    as for what software i have used I've tried most
    the HD files from the Panasonic recorder go on to the hard drive and then i transfer them to a disc. outher blu-ray players will play the files but no sound as for computer software the files wont load at all hence no picture or sound
  4. If that is all you have for the text view then the file is corrupt or encrypted...somehow.
    If it's genuinely HD then I am surprised you got it play on another player.
    Try loading it into Tsmuxer. See if it recognizes the streams and report any errors.
  5. Originally Posted by transporterfan View Post
    i have just found that arcsoft will play the disc from the USB BLU-RAY player attached to the computer no sound thou
    arcsoft however will not play the file from the computer however no sound or picture failure to load comes up
    tsMuxeR cant detect stream type ?
    the files are spot on and will play on all blu-ray players to hand just no sound
    the Panasonic recorder plays both sound and picture as you would expect
  6. Yeah. Sounds like encryption. I don't think you can play both video and audio together.
    Sorry. I can't fix that one for you. Maybe another member can chip in.
    I think most of them will say the same though.
  7. Originally Posted by transporterfan View Post
    thanks anyhow for your input
    I'm told it's because the sound has a custom codac as freeview HD is not a ble-ray spec at 720 HD so the file transfer is ok in the picture but the sound has to be modified somehow in the transferring to the disc hence the loss of sound
    it is not encrypted i have been told it's just a oddity to which i don't understand on the sound part
  8. Did you try vlc ?
  9. Originally Posted by poisondeathray View Post
    Did you try vlc ?
    yes I've tried that just arcsoft and power DVD only at this time with no sound perfect picture
  10. can you post a short sample ?
  11. Originally Posted by poisondeathray View Post
    a short sample of the file ? maybe i tried to cut it but it failed for some reason
  12. Originally Posted by fourbanks View Post
    of what ?
    obviously a sample of the m2ts file that you're having problems with
    record something short if you don't have a tiny sample
    what model is this "panasonic recorder" ? how do you have this connected ?
  13. Originally Posted by poisondeathray View Post
    of what ?
    the model is the 720 i will get a 15 minute sample and post it sometime tomorrow in HD connected via HDMI TO TV
  14. the file upload doesn't work for me so will have to try later
  15. Perhaps you hit filesize limits? You don't need 15min sample, a few seconds will do
    Some filetypes are not registered for the upload box here, Try zipping it up first (e.g. 7zip, winrar)
  16. Originally Posted by poisondeathray View Post
    it was only a 5 minute clip but as you say will try 7zip and try tomorrow
  17. here we go and fingers crossed someone can work out what sound codec is missing
    i have the AACS folder to upload if you need that ? and the rest of the BDAV folder ?
    http://files.videohelp.com/u/206594/00001.m2ts
  18. Neither commercial (VideoRedo, TMPG, ConvertXtoDVD, Corel, Wonderfox, Aieesoft) nor free (FFmpeg, Format Factory, Pazera, Freemake, HDConvertToX, and a host of others not listed) could identify anything in that file. No video. No Audio.
    Every player exulted by members on here failed. I don't know how you manage to get picture playback (having said that my vlc isn't up to date). Also, if you can play video I don't understand why you can't manage to demux it. Identifying the video format would narrow the options for audio considerably.
  19. Originally Posted by transporterfan View Post
    as i said before the file that i uploaded was uploaded from the computer not directly from the blu-ray disc player on the computer there are other files which maybe needed ?
    as i said before also the file will only play with arcsoft from the blu-ray player on the computer it will not play the file once transferred onto the computer arcsoft wont play the stream it is needing the full information from the other files i feel that are on the disc and are being read in a sequence that the arcsoft software understands ?
    i will up load those and maybe with all the files loaded and downloaded and then put on to a disc someone will be then in my position with a working disc but no sound ?
    http://files.videohelp.com/u/206594/00001.rpls
    http://files.videohelp.com/u/206594/CPSUnit00001.cci
    http://files.videohelp.com/u/206594/info.bdav
    http://files.videohelp.com/u/206594/MKB_RW.inf
    http://files.videohelp.com/u/206594/Unit_Key_RW.inf
    once downloaded the file structure should consist of the following
    2 folders one AACS and one BDAV
    in the AACS folder the files there should contain as follows
    MKB_RW
    AACS_av (file folder)
    Unit_Key_RW
    CPSUnit00001.cci
    in the BDAV folder the files there should contain as follows
    info.bdav
    PLAYLIST (file folder)
    00001
    CLIPINF (file folder)
    00001
    As i say hopefully someone will construct these downloads and get it to play in something other then arcsoft hopefully with some sound and a big thanks to anyone giving this a try
    a free trial for arcsoft can be found here i have the paid version
    http://www.arcsoft.com/totalmedia-theatre/
