Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
    Jun 2014
    san jose ca
    i tried it once and the quality was terrible can any one help with the right settings or better software and how to use it to keep original quallity
    Mar 2008
    If you're trying to create a regular DVD that will play on the computer and standalone players,
    try AVStoDVD.
    The 800 MB's of the source files is irrelevant, only the playing time (hours and minutes) is a factor.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    That's because you are trying to stuff two full length movies onto one single layer DVD. Can you go into a store and buy something like that?
    No. Just one of those movies most likely requires a dual/double layer DVD.
    PLUS your 800MB downloaded torrent crap is about 1/5th of the quality of the original DVD because of re-encoding, now you want to re-encode it again and expect "quality".
    Ridiculous.
