Closed Thread
  1. I downloaded Legend Of Korra S2 episodes in mkv and a subtitle file from a local site (.srt) and merged them together using mkvmerge GUI.
    I then put the combined file on a disk-on-key, connected it to my LG TV and the video and sound would work perfect but the subtitles wont appear . can anybody help me ?
    P.S when I opened the combined file on the computer the subtitles appeared.
    edit: typos.
    Aug 2006
    The TV's manual will have a section that describes what subtitle formats the media player supports. This section of the manual will also tell you if subtitles are playable if they are muxed into an mkv file or if subtitles are playable only if they are included as separate files in the same folder as the mkv file. Read it.
  3. Banned
    Freedonia
    Also, if these subtitles are in a language that does not use the Latin alphabet (ie. Greek, Chinese, Japanese, Russian, Thai, etc.) that may be a problem if you bought your TV in a country where that language is not a national language. Non-Latin character sets can be problems and only certain code pages may be supported or for some languages the TV may not play them at all no matter what you do.
  4. Originally Posted by usually_quiet View Post
    couldnt find it in the manual or in the user guide which is in the TV but i found this http://www.ehow.com/info_12198868_formats-lg-led-tv-support.html and according to this my TV should support .srt , couldnt find if it needs to be muxed or not
    its a non-latin alphabet but its the national lanaguage
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    The other possibility is the mkv support of the TV does not include having subtitles merged in the mkv container . Take the subs out of the mkv file and put the srt file in the same folder as the mkv file making sure the srt file name is identical to the video file.
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
  6. Most devices won't play subtitle that are muxed into an MKV file. Leave them as a separate MKV file with the same base name as the video.
  7. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Sorry, Yuvalyo. That video series appears to be copywrited and DL'ing it would be a violation of our Warez rule.
    Thread closed.
    Moderator redwudz
