  1. Hello cats,
    please do you know a plugin for VLC or other program that do Waveform/Vectorscope on a video file?
    thanks
    ps. this 2 files are bars from my camera in Hd mode:
    https://dl.dropboxusercontent.com/u/39871584/barsHD.MXF
    and SD mode:
    https://dl.dropboxusercontent.com/u/39871584/barsSD.MXF
  2. Most decent NLE's will have them
    vdub color tools plugin by trevlac
    avisynth histogram , histogram("color")
    ffmpeg/ffplay -vf histogram, either colors, waveform, levels modes
    https://www.ffmpeg.org/ffmpeg-filters.html#histogram
  3. mm thanks, but how is the commandline to generate a video file with "overimpressed" vector/waveform?
  4. Code:
    ffplay -i "barsSD.MXF" -vf "split[a][b];[a]format=gray,histogram=mode=waveform:waveform_mode=column,vflip,split[c][d];[b]pad=iw:ih+256[padded];[c]geq=g=1:b=1[red];[d]geq=r=1:b=1,crop=in_w:220:0:16[mid];[red][mid]overlay=0:16[wave];[padded][wave]overlay=0:H-h"
    Or just use a NLE , probably easier
  5. mmm I think is beautiful with ffmpeg, only I cannot see the "scale" in volt, for example my analog waveform indicate the 1Vp/p on the blank bar, whit this commandline seems similar but have not the scale that indicate level in millivolt, is there a way to see it? thanks
  6. Not sure how to display that in ffplay with mV (PAL) , IRE (NTSC) . Premiere's waveform can display that
    Most digital waveform tend to use 0-255 scale now, not analog units
