  1. Member loa909's Avatar
    Mar 2007
    Hi all I downloaded a movie clip from youtube with YTD youtube downloader but if i play the clip with WMP or VLC the annotations dont work or show on screen but they do if i play clip on youtube. is there a program to let me see annotations
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If the annotations are not there in the file on your computer....then no.
  3. Member loa909's Avatar
    Mar 2007
    How do you mean I didnt do the annotations a friend did. and they show up ok if I play clip in UT and I didnt have the Annotations
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    The annotations are just text overlays within Youtube. Sort of like subtitles on a DVD.....they are not part of the video stream.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    https://ttsiodras.github.io/youtube.html but it looks very complex....
    Or else use a screen grabber to record the video with annotations.
  6. Member loa909's Avatar
    Mar 2007
    Lol Yes that link is well complicated so what do you suggest what screen grabbers can record vids with annotations help is much appreciated
    Can no one help on this please as not had anymore replies
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    You can record youtube with Mirillis ACtion or the free open broadcaster software(it worked pretty ok for me...but still beta).
  8. Member loa909's Avatar
    Mar 2007
    Ok many thanks for help, will these still show the annotations
