Results 1 to 9 of 9
  1. Hi,
    I prefer to deliver the audio with the highest quality possible because Youtube loves to re-encode everything.
    How can you make Ripbot to encode the audio at 320 kbps aac or better yet 384kbps if the dropdown menu only offers up to 192 kbps?
  2. You can put the cursor there and enter a value, you're not limited to using the dropdown
  3. Originally Posted by poisondeathray View Post
    That's odd, I'm using Ripbot 1.17.5 and whenever I click on the audio profile field it opens the dropdown list. If I start typing nothing changes.
  4. Sorry I was going by memory - maybe I was thinking of an older version or confusing it with the video bitrate which you used to be able to enter manually
    You can submit a request to the Atak to add in more audio profiles/options
    or you can use something else that allows you more control e.g. megui
  5. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Easy.
    Select your file, choose settings. Go to Ripbot temp folder and edit job1_EncodeAudio.cmd (screen below):
  6. Thank you Cauptain that did it!
    Is it normal to have 6 channels listed in the codec information of the video?
    SampleRate(Sample/sec) : 48000
    BitRate(Bit/sample) : 16
    Channels : 6
    KBitRate(KBit/sec) : 384
  7. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Channels : 6
    Please post a mediainfo from your selected file here.
  8. MediaInfo says 2 channels ☺
    General
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 117 MiB
    Duration : 5mn 8s
    Overall bit rate : 3 173 Kbps
    Encoded date : UTC 2014-07-02 00:10:26
    Tagged date : UTC 2014-07-02 00:10:26
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 5mn 8s
    Bit rate mode : Variable
    Bit rate : 2 786 Kbps
    Maximum bit rate : 25.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.054
    Stream size : 102 MiB (88%)
    Title : drugtrips-cq-noTune-384
    Writing library : x264 core 135 r2345 f0c1c53
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=25.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
    Tagged date : UTC 2014-07-02 00:10:28
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 5mn 8s
    Bit rate : 384 Kbps
    Maximum bit rate : 393 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 14.1 MiB (12%)
    Encoded date : UTC 2014-07-02 00:10:28
  9. Hi guys, I'm reviving this thread to post an easy script to change the audio in Ripbot which can be opened from the desktop.
    It involves two files inside the RipBot264temp folder:
    batch.ps1:
    Get-ChildItem *.cmd -Recurse | ForEach-Object { (Get-Content $_) | ForEach-Object { $_ -replace '128','384' } | Set-Content $_ }
    batch.bat:
    CD /D %root% C:\temp\RipBot264temp
    powershell.exe -ExecutionPolicy ByPass -file batch.ps1
    Make a shortcut for batch.bat which can be opened from anywhere. I set the quality to 384 as you can see in the batch.ps1. Change it to the bitrate you need and voila.
    Bear in mind that it applies to every job you have on queue. Any job at 128 kbps will be replaced!
    The script is attached as well.
