  1. I've a movie in AVI format and separate .SRT subtitle file, how do I add the subtitle file to the video as I want both in one file like MKV
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    AVI-Mux GUI, possibly VirtualDubMod (as you have a SRT-format subtitle file), I believe, though I probably wouldn't recommend using VirtualDubMod. Or, you could also remux all three streams (video, audio and subs) into an MKV.
  3. Originally Posted by Ai Haibara View Post
    If I use MKVToolNix to remux the subtitle into video, the audio & video quality and bitrate will remain the same?
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Simply run MKVMergeGui, part of MKVToolNix, and drag both the avi and srt file into the top window. Press "start muxing" and a few minutes later a mkv file, no re-encoding, no change in quality..
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
  5. If I use MKVToolNix to remux the subtitle into video, the audio & video quality and bitrate will remain the same?
    yes, mkvtoolnix only switches the container, it doesn't change the audio/video/subtitle data itself.
