Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Is 624x350 High Definition
  2. Generally 1280x720 is the minimum considered HD.
  3. Originally Posted by smrpix View Post
    what is hdtv? someone offered me a disc he taped from tv. it is hdtv. Would it look ok on a 32inch flat scvreen
    May 2014
    Tennessee, US
    Originally Posted by Dopey2013 View Post
    what is hdtv?
    http://www.videohelp.com/glossary?H#HDTV.
    LOL! How do you "tape" to a disc? I think maybe you mean that someone recorded a tv show to a digital disc.
    No, discs are not "hdtv". An HDTV is a TV display device, not a disc.
    A disc can contain video data in many formats. Is it a DVD? AVCHD? BluRay? Do you have a disc player for it?
    A "flat screen" isn't necessarily an HDTV. CRT's came in flat screens, too. I think you mean you have an LCD television set.
    If you want to know if the disc will display on your TV, put it in a player and find out. If the disc was made correctly, it should play anywhere. We wouldn't know if the disc is SD or HD. But it should play on any TV whether the TV is HDTV or not.
    - My sister Ann's brother
  5. Originally Posted by LMotlow View Post
    what is hdtv?
    yes lol
