  1. I have to uninstall VideoPad to fix an error. However, I'm worried that it will ruin a project I'm currently doing. Will uninstalling the program and reinstalling it have any effect on my project? Will it still be the same after I reinstall the program? Thanks.
  2. What is the error ? Can you work around it ?
    It probably won't affect the saved project, but as a general rule you shouldn't make any updates/changes to software until you finish that project to be safe - that applies to all software
