    Jun 2014
    Tunisia
    I use STOIK Capturer to capture from my DV camera and there is a list of compression Codecs. I am kind of a newbie so I was wondering if you guys would recommend me the best codec that guarantees GOOD QUALITY and small size. I don't want to have a big quality drop.
    Here is the list.
    Just copy the dv video with WINDV. Then convert/edit the video to a smaller format.
    Or else if you want to shrink directly while capturing then try wmvideo9 for smallest size. If too bad quality try mjpeg.
    Jun 2014
    Tunisia
    Thanks a lot. I'll go with wmvideo9.
