    Jun 2014
    san jose ca
    movie files are less then a gig each, my blank dvds are 4.7 gigs, tried nero and dvd flick (takes way to long to make an iso file) , is there any easier way so i can watch my movies in a dvd player, would settle for just two movies per dvd..... thanks for reading any help is appreciated
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    I assume you mean a video ts folder?
    You have to encode them as mpeg 2 and author it as a DVD properly.
    USe avstodvd to do this.
    If you use a dual layer blank you'll be able to use a better bitrate.
    You should limit it two for better quality.
    Sent from my Nexus 7 using Tapatalk
    Nov 2003
    West Texas
    Depends on what formats your DVD player can handle on a burned disc. If it can play Xvid AVI files, or mp4 or mkv files, you'd have a better chance of fitting three full length movies onto a single layer disc with acceptable video quality. For these formats, just burn the discs as ordinary data files.
    If you need DVD-video, you'd best check the running time of the three movies. I wouldn't try to put more than 2 to 2/12 hrs on a single layer disc. AVStoDVD is your best shot at converting to DVD-video, as already mentioned.
