    Jun 2014
    australia
    I need to convert ifo files at the moment but I would like to get the best converter for all files.
  2. Member turk690's Avatar
    Jul 2003
    ON, Canada
    convert ifo files to what?
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
    Aug 2013
    Central Germany
    There is no best converter for all kinds of media files and all kinds of users. Each user has an own optimum between usability, quality preservation, size reduction and speed. And each pair of source and target format may have a different set of tools to achieve a conversion with specific side conditions.
    Mar 2011
    Nova Scotia, Canada
    There are lots of good tools recommended here by some very knowledgeable videoe geeks, but unfortunately they are not noob friendly. At all.
    There are also a bunch of free "easy to use" ones. If you're a lazy using your search engine that'll be mostly what you'll find because they all seem to use SEO. But they're terrible. I don't know of any good ones.
    The only ones I know of that have good power and reasonable ease of use are handbrake, vidcoder (really handbrake with a different front end) and avidemux.
