  1. Member Ogilvy's Avatar
    Jul 2005
    Germany
    Hello I have a quick question on the “Video to Video “software’s Commercial remover. On the internal player, it doesn’t play any sound. Is this right? Is it a bug? It makes exact cutting difficult. Obliged for any help here
    Most (free) editors does not play any audio.
  3. Instead of playing the audio, many video editors can show the audio waveform.
    I have not ever used V2V so I cannot tell if it has such feature.
  4. Member Ogilvy's Avatar
    Jul 2005
    Germany
    Is there a way that the vlc player can show exactly which frame is currently playing, so that I know where to break video exactly please?
  5. ..I'd suggest you to use a real video editor to do the cutting, should save you a lot of trouble...
    AviUtl, VirtualDub, Vegas...
