  1. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Hi, There!
    I have many DVDs (Full Screen) 4:3 and I want to watch it on TV (Wide Screen) 16:9.
    Is there is any way to convert it into 16:9? Thanks in advance
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    If it's not letterboxed (Ie the black bars inside the 4:3 frame) then it's not really worth it.
    You'll have it stretched and stuff will be left off the edges.
    I seem to remember that windows media center had an awesome zoom feature that seemed to flawlessly auto stretch 4:3 to 16:9 without distortion. But it's been so long since I've done that I could be mistaken.
    Basically I would not suggest doing that in anyway.
    If you must fill the screen why not just use the zoom button on your tv or dvd player? Then see if you like it and just leave it that way. No conversion needed.
    However chances are stuff will be lost on the edges (not permanently of course just while zoomed). Also you may have problems with subtitles in this mode - also if they are hardcoded into the picture they'll be stretched and distorted also.
  3. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Thank you so much
    Sep 2012
    Australia
    Well, there are options. You could use MakeMKV to mux them into an MKV then set croppings for an automatic zoom for any player that understands them. You can just change the Aspect Ratio from 4:3 to 16:9 and watched them stretched. Neither options require a re-encode. Any further solutions will simply be a variations on stretching and cropping.
  5. Member wulf109's Avatar
    Jul 2002
    Flatscreen TV's all contain a menu option to zoom 4:3 to 16:9 by cropping the top and bottom of the frame and generally provide a better picture than encoding. I have an LG BR player that zooms the picture in 2% increments from 2-32%.
  6. Originally Posted by TeNSoR View Post
    You can already watch 4:3 DVDs on your widescreen TV set. The player just adds black bars on the sides. Wanting to watch a 4:3 film (not a widescreen 4:3 film) any other way is the result of ignorance because it means changing the OAR (original aspect ratio) in one way or another.
