I would like to be able to start a recording using fraps,dxtory, or even the avermedia live gamer HD recording button and instantly remove the clip.
For instance you start recording and then 40 seconds later you realize the clip isn't going anywhere. I would like a way to instantly remove the file with a hot key for any of these programs is this possible?
Another example, normally your recording button is say f9 and then you press f9 again to stop. Is there a way to make f10 stop but not save the clip?
