Closed Thread
  1. Hi,
    I've been capturing the analog RCA/Composite video contents (including AUDIO) coming from my Satellite Receiver (or) DVD Player (and then Stream out to my Wowza Server). I've been using only of:
    But this Products are ending or even ended. I choose this one previously because it is simply come with R,C,A Ports and also PCI.
    * Then again because of the 24/7 run, i totally dont want to use USB interfaces.
    Now moving forward, can you all please advise which are the best replacements for that kind of Card above, in the market please.
    a.k.a
    What are the all possible alternative ways to capture the RCA/Composite Analog Contents (including Audio) to PC, without using USB ones.
    I don't mind anything but as long as PCI or PCIe.
    So to wrap up the scenario, the requirements to choose a better CARD would be:
    - Capture RCA/Composite Video+Audio Channel
    - Should NOT be USB Interface.
    - Run on Windows
    - Would be better if confirmed working with WIRECAST Broadcasting Software.
    Hoping for you to kindly share your experience and suggestions.
    Thank you so much.
    Best,
    4lvin
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    4lvin, Do not post the same topic on several forums.
    Please do not cross post, once is enough.
    Continue in: http://forum.videohelp.com/threads/365208-PCI-e-Capture-Card-for-RCA-Composite-Channel...53#post2327953
    Moderator redwudz
