  1. Member brassplyer's Avatar
    Apr 2008
    Let's say I have a 90 gig video file on drive D: and I want to split it up into specific-size segments and send them to drive E: to ultimately archive on Blu-Ray - i.e. so none of the segments are too big to fit on a Blu-Ray disk.
    Does an app like that exist?
  2. Member Cornucopia's Avatar
    Yes.
    Do you need them to be playable in their parts? Or just when put back together?
    Because 7z/Zip/Rar with file-disc-spanning could do it (the latter), as well as the common "HJ Split" (or similar permutations).
    If you need the former, you can use a number of cutter apps. Virtualdub specifically has an AVI export/save option that allows you to limit by size. You can also use Cuttermaran for MPEG, and I'm sure there are other apps out there (just haven't looked up this feature in a while as the need for it has declined greatly).
  3. Member brassplyer's Avatar
    Apr 2008
    Yes.
    Just when put back together. Just as a backup in the event of drive failure so I don't lose the file.
    It appears to be "Save segmented avi". Hadn't explored this before.
    Thanks!
  4. Member Cornucopia's Avatar
    BTW, if you do this, I STRONGLY recommend you save an Un-cut copy of the whole length audio file, whether as the main audio or in addition. Avoids getting glitches in the samples. Good as a reference (when in addition), and doesn't use up much overall space (compared to the video).
  5. MKVMergeGUI should be able to do it (it has a "split after size" option). It can also link the split files so a player which supports linked MKVs will play them as a single file. It'll also open various file types (output is always MKV).
    Sep 2012
    Australia
    I wouldn't use MKVMerge on a Blu Ray M2TS file with TrueHD audio if you intend to put it back on a Blu Ray. But for general purpose/multicodec video storage/cutting MKVMerge would be the best option.
  7. Guest34343
    Guest
    If you just want binary split, there is DGSplit also.
