Hey, how can I remove these pixels with Avisynth?
http://puu.sh/9rBc6/782199ac68.png
Greeting
Guest34343Guest
That is dot crawl.
http://avisynth.nl/index.php/Category:Rainbow_%26_Dot_Crawl_Removal -
I find PAL dot crawl a lot harder to remove than NTSC dot crawl. Because NTSC dot crawl has a pattern that repeats every 2 frames, PAL dot crawl has a 4 frame pattern. You generally need to run dot crawl removal filters while the video is interlaced.
