Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 85
    Mar 2012
    Hi, i'm trying to rip from a DVD into a raw MPG2 file (i.e. without re-encoding) from the VOBs, but i'm having trouble removing the pulldown flags.
    The title I want to rip is structured in 4 VOB files, and this is where the problem lies. According to eac3to, the video format of the first file (it's an NTSC DVD) is:
    "MPEG2, 480i60 /1.001 (16:9)"
    i.e. it can't find any pulldown flags, so using -stripPulldown has no effect as it appears not to attempt to remove any.
    However for the other 3 VOB files, the format is:
    MPEG2, 480p24 /1.001 (16:9) with pulldown flags
    If I run eac3to with the -stripPulldown argument for these 3 VOB files to create a joined VOB file, it attempts to remove the flags this time, although it then says:
    The MPEG2 stream is a mixture of progressive and interlaced encoding. The Pulldown cannot be removed from this type of MPEG2 stream. Will have to abort processing and redo everything.
    My ultimate goal is to demux the 4 VOBs into joined demuxed files, while removing the pulldown flags on the video track at the same time, something along this command:
    eac3to 1.VOB+2.VOB+3.VOB+4.VOB -demux -stripPulldown
    If I include the 1st vob in this command, as eac3to doesn't detect any pulldown flags, it doesn't attempt to remove them from the other 3 VOBs, yet if I leave off the 1st vob from that command, it gives me the "Pulldown cannot be removed" errors as above.
    What's going on? Can you help?
  2. Guest34343
    Guest
    There are ways to do it but it's inadvisable.
    One option:
    You can load all the VOBs into DGIndex and then demux the video to a single M2V. Then use DGPulldown to remove the pulldown flags.
    The problem with this is it will likely destroy audio sync, and I suppose that is why eac3to disallows this operation.
    Second option:
    Use eac3to individually on each VOB, then binary concatenate the resulting M2Vs. Again, it will probably ruin audio sync.
  3. DECEASED
    Jun 2009
    Heaven
    Just use PGCDemux, and forget about removing the pulldown flags, because
  4. Originally Posted by bergqvistjl View Post
    There's your problem. You cannot produce a progressive video from that without reencoding.
  5. Guest34343
    Guest
    Not necessarily. The content itself may be progressive but is just encoded interlaced. It is quite common.
    Mar 2012
    Damn. I tried to remove the pulldown in tsmuxer, but it complained that:
    Warning! Source stream contain irregular pulldown marks. Mistiming between original fps and fps/1.25(without pulldown) exceed 100ms.
    Ah well, such a shame. I thought DVD's didn't allow mpegs that alternate between progressive and interlaced. Weird. So is there no way to remove the pulldown at all then, even if I did re-encode it?
  7. Guest34343
    Guest
    Of course you can if you re-encode. If the pulldown is irregular, then use DGindex with Honor Pulldown and then do external IVTC with Telecide()/Decimate() or TFM()/TDecimate(). Don't use Force Film as it will destroy audio sync.
    If you actually have a hybrid of progressive and interlaced *content* things get more complicated.
  8. Originally Posted by neuron2 View Post
    Yes, but like you said, he's likely to get A/V sync problems. In my experience PAL with pulldown flags is usually 2:2:2:2:2:2:2:2:2:2:2:3 pulldown to convert 24 frames per second to 50 fields per second.
    Mar 2012
    I'm guessing setting it to "ignore pulldown" in DGindex and demuxing won't remove the pulldown either? (The default is Honor)
  10. Guest34343
    Guest
    He won't get audio desync from correct IVTC. OP said it is an NTSC DVD!
  11. Guest34343
    Guest
    Demuxing is raw; it is not affected by the selected field operation.
    Mar 2012
    Can you rephrase that please? What does that mean in terms of pulldown? I mean, if it does't affect it, why is the option there?
  13. He means demuxing simply demuxes -- including pulldown flags. The pulldown removal is only reflected in the index file.
  14. Guest34343
    Guest
    Yes, jagabo is correct.
    If you are bound and determined just to remove the flags and see what happens, then re-read my first post.
    Mar 2012
    I might just leave it. Seems more trouble that it's worth To me it looks like the content is actually progressive yet it's been encoded as a mixture of progressive and interlaced.
  16. Guest34343
    Guest
    If there is a mix of hard and soft telecine then re-encoding is unavoidable. A sample would be needed to advise you properly.
    Mar 2012
    Well the DVD is the double-sided NTSC Region 1 version of Stephen King's It. How do I take a sample without messing with the original encoding?
  18. Guest34343
    Guest
    Yes, you can set a range with the [ and ] keys, then demux as jagabo mentioned. That is convenient as it allows you to select the desired content.
    You can also cut the VOB directly with DGSplit.
    Try to provide sections from both the progressive-coded and the interlace-encoded VOBs.
    Mar 2012
    Both demuxed using Honor Pulldown
  20. Index with honor pulldown flags then TFM().TDecimate().
    Mar 2012
    Whereabouts is TFM().TDecimate() found?
  22. Guest34343
    Guest
    The interlaced portion appears to be only the first 42 black frames at the start, and the rest is pure soft 3:2 pulldown.
    You can use Force Film in DGIndex or you can do external IVTC. The first will be much faster and you don't have to worry about TFM/TDecimate.
    Removing the pulldown without re-encoding is also an option.
  23. Member
    Mar 2012
    Argh, right well im confused now..... So many different options...
    I would like to remove the pulldown without re-encoding. How do I do that?
  24. Guest34343
    Guest
    Either of the methods in my first post.
    Of course, you will have to remux the audio and video again after you remove the pulldown from the elementary stream. You may also need a slight audio offset to account for the desync of the first 42 frames. But it will be a constant offset and will not grow throughout the stream (assuming the stream is indeed soft 3:2 throughout).
  25. Member
    Mar 2012
    OK, so i'm going to demux the 4 VOB files together using DGIndex, followed by running them through DGPulldown to remove the pulldown.
    When demuxing them through DGIndex, do I Honor Pulldown, ignore it, or use film mode?
    Also, Correct me if i'm wrong here, but the source framerate is currently 29.97 and I want to end up with 23.976?
    Finally, what settings do I set for DGPulldown?
  26. Guest34343
    Guest
    Correct.
    As we told you, it doesn't matter. The field operation is not used when demuxing.
    Yes. That will be done by DGPulldown.
    Read the included text file. Here is the key part:
    "Note that if the custom rate conversion is selected, and if the source rate is
    specified as equal to the destination rate, then all pulldown is removed and the
    stream is flagged as having a rate equal to the specified destination rate."
    So, use custom rate with both source and destination frame rate set to 23.976 fps.
    I tested it on your second sample and it works just fine.
  27. Member
    Mar 2012
    Correct.
    I'll give it a go How (or where) should I account for the 43 frame delay in the audio? I'm not sure what tool to use when remuxing again...
  28. Member
    Mar 2012
    Correct.
    Well i've done it on all 4 vobs and it works fine, thanks What tool should I re-use for muxing back into an MPEG file, and how do I account for the 43sec delay in the audio tracks?
  29. Guest34343
    Guest
    It depends a bit on your audio type. What is the filename (with extension) of the demuxed audio that you would like to use?
