  1. Member Caiosouza's Avatar
    Nov 2013
    Capćo da Canoa, RS, Brazil
    Hello all, could anyone know is there any script to
    Avisynth, which simulates Phosphor deinterlace filter of the VLC player?
    Or, if there is any way to save the video with this filter applied?
    Thanks all,
    https://wiki.videolan.org/Deinterlacing
  2. That's damn ugly and nothing like what you would see on a CRT. A simple bob is more like a CRT TV. But if you really want to do that you can probably come close using SeparateFields(), SelectEven(), SelectOdd(), Tweak(), and Weave(). I'll have to think about it...
    By the way, if you're planning compressing the resulting video the technique is going to kill the compressibility.
  3. Here's what I've come up with:
    function SomethingLikeVlcPhosphor(clip vid, float "fade")
        fade = default(fade, 0.4)
        SeparateFields(vid)
        even=last
        odd=Trim(1,0)
        even=Interleave(even.SelectEven().Tweak(cont=fade, sat=fade), even.SelectOdd())
        even=Weave(even)
        odd=Interleave(odd.SelectEven().Tweak(cont=fade, sat=fade), odd.SelectOdd())
        odd=Weave(odd)
        Interleave(even,odd)
    AviSource("dv.avi")
    SomethingLikeVlcPhosphor(0.3)
    Adjust the fade value to your liking. I was testing with a BFF DV AVI file but I'm pretty sure it will work with a TFF video as well.
  4. Member Caiosouza's Avatar
    Nov 2013
    In the pic this filter even looks horrible, but try taking a low quality video and apply this filter in VLC> Video> Deinterlace>On> Mode> Phosphor.
    Is an excellent filter to watch low quality videos that are very bad for LCD monitor,I would like to apply this on converting in some videos.
  5. You'd be far better off with QTGMC() followed by an upscale with nnedi3_rpow2().
