Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
    Oct 2008
    Hello
    I cannot burn video folders from hard-drive The video files are avalible i can play them with VLC
    Can someone please advise how to correct this problem so i can carry on burning?
  2. That program looks like one of those "also ran" copycats that pretend to be better than all the rest, CloneDVD is the real leader. Not to put down your choice of software, just saying that in this case anything could cause your issue.
    First thing that comes to mind is shorten the folder/file name to episode1 and try again.
    It could be a permissions problem, if you have a second drive copy the files there. It might also work if you move them to your documents folder.
    Oct 2008
    I installed CloneDVD and DVDFab, both worked.
    Thanks nic2k4
