    Mar 2008
    Singapore
    as above - i'm using the latest version of potplayer. any idea why only this software doesn't respond to the Win+Right hotkey? the window just stays in its position and i have to manually adjust the window size for it to fit the right half of my monitor.
    Mar 2008
    Singapore
    doesn't seem like it - the previous version (before their major UI overhaul) had the same problem.
  3. I don't know the details but it's possible with a window frame skin.
    Mar 2008
    Singapore
    you're totally right - it's the skin problem.
    i've notified the developer - hope he can fix it soon.
    thanks peeps.
  5. I don't think it's a skin problem.. probably the default skin does not use something like windows controls. A skinned application without a window frame seems not work like that. For example, jriver mc does not react with win + arrow keys.
