    Mar 2014
    US
    I have an aging game (NFS4) that I'd like to archive. ImgBurn is coming up with read errors during ISO creation, but I just tested and the game installs and plays with no issues. Any suggestions?
  2. Alcohol 120% can backup PC games DVDs, you have trial 15 days
    Some times if game don't play, after install from backup ISO or DVD
    you need download fix file from http://www.gamecopyworld.com/
  3. Originally Posted by bqi View Post
    If it's an original game, then it is copy protected.
    There are different software that could be used to circumvent this.
    Either Alcohol 120% or Daemon tools can usually copy most games.
    This may be considered illegal in some countries.
    Mar 2014
    US
    DTLite seems to have hit a similar problem "Read operation hit a bad (unrecoverable) block (816)"
    Strange I was able to install the game and play with no issues, but I cannot create an ISO for safe keeping.
  5. So try with Alcohol 120% be sure that Skip error reading selected
    don't worry about trial, you can use image after trial ends
    in freeware Alcohol 52%
  6. Yeah backing up the disc can be dicey. Sometimes you need to download a hacked .exe to load it from the virtual drive... Try using a good brand name of disc tho'. Like Verbatim's for some reason are better for playing 'backups'.
