    Jun 2014
    Sarasota, Florida
    I'm trying to record gameplay on my Windows XP computer, with a Dazzle DVC 100, using the Lagarith codec. The video looks fine, but the audio is constantly desyncing. Is there a fix to this?
  2. DECEASED
    Jun 2009
    Heaven
    It depends on:
    0) the resolution and the framerate of your video capture;
    1) how fast or how slow is the processor of your computer;
    2) if you're saving the capture file to a secondary hard drive, or not;
    3) if there are "too many" needless processes or services running in the background;
    Jun 2014
    Sarasota, Florida
    Originally Posted by El Heggunte View Post
    It depends on:
    0) Frame rate is 30 FPS
    1) The computer processor is probably in-between fast/slow.
    2) If I saved the capture file to a flash drive or something, could that fix the problem?
    3. There are no other applications open besides VDUB. I get no frame rate lag when recording, just audio desync.
    Any recommendations?
