Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Hello there.
    I have 10 high-resolution videos (h264) and i'd like to cut some parts outta them and also 'merge' them all in a single 15hrs file... It's okay to cut only at keyframes, i've tried avidemux but the output is choppy, like the framerate varies continuously from 10 to 90fps. (EDIT: forgot to mention that avidemux doesn't 'crop' the audio also')
    Is there any other program (with GUI please) that allows me to do that?
    Thank you in advance.
    Feb 2014
    Mumbai
    Before I can give you any hint , Are all videos having the same specs ? as in framerate , resolution, video/audio codec video/audio bitrate??
    And, did you already demux all the audio video streams from the containers?
    Feb 2008
    India
    Tmpgenc Smart renderer will do the job for you.
  4. Thank you for the replies.
    Placebo, yes the videos see identical. No idea what is demux.
    Addu, let me try that. Thank you.
  5. Demux
    Demuxing / demultiplexing basically means, when speaking of video formats, splitting the file that contains both audio and video data (and possible other data streams as well, like subtitles), into separate files, each containing one element of the original file.
    Demuxing file doesn't weaken the video or audio quality, it doesn't do anything for these data streams, it just simply saves them into separate files.
    Opposite of demux is muxing, which basically joins the datastreams back together.
