Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 13 of 13
    May 2014
    México
    Hello, first of all, I'm new in this forum, so I hope I can help others.
    Okay, here is my question: What is the best HDD recorder out there? I'm thinking about switching from DVD Recording to this new methood of recording.
    Also, I would like to know if with the recorder is possible to put the recordings I do in a USB Drive.
    Thank you and have a nice day.
    Aug 2006
    Best HDD recorder for what kind of TV broadcast source? Is this for over-the-air digital (ATSC) TV or do you intend to record something else?
    May 2014
    México
    I could use it for the local channels, but I would like one that supports my digital cable tv box. The box has the RCA plugs.
    Aug 2006
    Maybe someone from Mexico knows of a recording device that does all of the things that you want but I do not. In the USA, I have seen a few different recording devices with an ATSC tuner (digital over-the-air TV tuner) that can schedule recordings and store them on a USB hard drive, but none can also record the output from a cable box.
    However, it is possible to customize a PC to allow it to control a cable box and record its output as well as record local over-the-air broadcast stations. I have done that.
    Feb 2006
    if you try to record from your digital cable tv box. you may run into some kind of copy protection.
    May 2014
    México
    usually_quiet: Almost nobody knows about these things over here, so this is why I'm asking over here.
    october262: I haven't ran into a Copy Protection, because I've been recording many stuff from it with my DVD recorder since 2012.
    Jul 2008
    Old Dominion
    Magnavox manufactures HDD/DVD recorders, so you might want to check their web site to see if the units they have available meet your needs. Walmart carries them on their web site as well. I had an early model that worked well enough, but limited to Standard Definition recording. This early unit had input via the built-in digital Tuner or S-video.
    May 2014
    México
    I actually own a Magnavox DVD Recorder, it's a very simple model that it only records to DVD, doesn't have the HDD feature.
    Like mentioned earlier, I live in Mexico, mexican Walmart doesn't sell anything like that unfortunately.
    Aug 2006
    I have a Magnavox HDD DVD recorder as well but did not suggest one because you said you did not want a DVD recorder. They do work well, but as mentioned previously only record in standard definition. I looked on MercadoLibre, and saw a few listed but the asking price seemed outrageous.
    May 2014
    México
    I said I own a Magnavox DVD Recorder, I bought it on MercadoLibre when it was reasonably cheap (Thank god I did that). Last time I checked the device with the same seller I bught it, it cost more expensive than it did 2 years ago.
    May 2014
    México
    I think most DVD Recorders on MercadoLibre are way more expensive than buying them on the product's official page tho.
    Aug 2006
    There are a few other things about the Magnavox DVD recorders with a hard drive that I forgot to mention. The hard drive (pre-installed by the maker) is internal. There is no way to connect a USB drive. Recordings on the hard drive are encrypted, so you won't be able to save recordings without dubbing them to a DVD. Also, if your cable box applies analog copy-once protection to the composite video signal for some program that you record, then you will not be able to dub that recording to a DVD.
    May 2014
    México
    I think the cable box doesn't do the ''analog copy-once protection'' because I was able to record many stuff from my TV and then save in many DVD's those stuff
