Hi everybody!
I need Your help!
I have a sony ax-2000 camcorder. If i record a longer schnitt, then 12min 42 sec it split video files.
TsMuxer is a fantastic tool for me, becase it can merge this video files.
I recorded a wedding day, so i have lot's of long video.
I would like to create a program, that auto merge this files.
If i add a video file and join an other the tsMuxer gui calculate a timeshift value (+-500ms).
I can not image how does it?
Can You help me?
P.S.: Sorry for my English
tsmuxer gives you the audio delay of existing files if you just enter the file name on the command line.
Redirect output to a file, parse the file for the stream delay, and apply it to your meta file.Code:D:\Downloads>"g:\program files\tsmuxer\tsmuxer" dump.ts Network Optix tsMuxeR. Version 2.6.11. www.networkoptix.com Track ID: 4113 Stream type: H.264 Stream ID: V_MPEG4/ISO/AVC Stream info: Profile: High@4.0 Resolution: 1920:1080i Frame rate: 29.97 Stream lang: Track ID: 4352 Stream type: AAC Stream ID: A_AAC Stream info: Sample Rate: 48KHz Channels: 2 Stream lang: Stream delay: -16 Duration: 26:30:43.717
