    May 2014
    England
    I have recently hooked up my Dazzle DVD Recorder HD to my Nintendo Wii and I am using xSplit to record it, however, the recording is in black and white.
    I have read that amcap is the program to use in order to fix this, however when I install amcap, every time I launch it I get a blue screen of death.
    I am therefore asking for one of two things:
    a) Is there an alternative to amcap which would allow me to record in colour
    b) Is there a way of stopping the BSOD when launching amcap
    I have already looked for various ways of stopping the BSOD however none of worked yet.
    Any help will be much appreciated
  2. You need a capture device/software that supports PAL60 -- NTSC scan rates with PAL chroma. The Dazzle dvc100 supports that with amcap -- maybe that's what you have. I don't know why amcap is having problems. What OS are you running? Try running in compatibility mode for earlier versions of Windows.
  3. Banned
    Freedonia
    I think you need a capture device/software that supports PAL60 -- NTSC scan rates with PAL chroma.
    This.
    Most capture devices can't capture PAL60 signals correctly and many games in PAL countries send out PAL60 signals.
    May 2014
    England
    I believe that the Dazzle DVD Recorder does support PAL 60 as I got it off of a recommendation from someone who uses it to record their Nintendo Wii.
    Correct me if I'm wrong, but I believe that amcam is the software that supports it, which unfortunately isn't working for me
    Aug 2006
    AmarecTV is a possibility, but it is a much more complex tool than Amcap. There is a guide here: https://kb.speeddemosarchive.com/Amarectv_configuration
    You need to set up the the drivers to use PAL_60. If using AmarecTV, you use the "Device Setting" button on the "Graph 1(Device)" Tab to access the analog capture properties dialog window for the device. Next, select "PAL_60" in the drop down list for the Video property in the small pop-up "Properties" window. If PAL_60 isn't on the list, then your device does not support it.
    I cannot give much more help than that. I never used AmarecTV very much, and never used XSplit at all because I don't capture video games, only TV shows from a set top box.
    May 2014
    England
    AmarecTv has been a great help, thanks for the suggestion.
    Pal 60 is on the list, however the screen now looks like it has a purple filter to it.
    I will keep trying to mess around with some settings and hopefully fix it.
    Thanks for the help quiet.
