  1. Hello!
    There seems to be a lot of them. Are there any particularly good ones? I have an Astrometa USB DVB-C Tuner (cheapest one available). It's software was rather pitiful. I tried SmartDVB but that was nonfunctional, it seems like it's only for satellites. ProgDVB works with issues. It crashes very often. The image freezes if I start whatever that requires admin rights. Also downscaling is (even using EVR CP) garbage, appalingly aliased. And I use it as a small window a lot.
    Maybe DVBViewer. It's not free though.
    Aug 2006
    NextPVR is another possibility. It lists DVB-C tuners as supported and it is free. Setting up the program guide can entail some work, and requires finding a source for the guide data.
  4. Thanks for the tips. I'll have a look.
    Is there one that can use madVR? At least that would properly downscale the video.
    Aug 2006
    Apparently, madVR doesn't work properly with NextPVR. EVR was recommended as an alternative by some members of NextPVR's user forum. http://forums.gbpvr.com/showthread.php?54615-madVR
  6. Well, NextPVR didn't work out. It does work poorly with madVR and EVR looks just as crappy as with ProgDVB. Also it can't function properly with LAV video codec which has a good HW decoder and deinterlacer... So more pain, no gain.
    I'll try the other later.
