I have a few MP4 X264 files that i would to put on Bluray Disc, but i do not want to re-encode them at all. i want them untouched. But i also want to add some sort of menu to the bluray.
Any ideas on what software i need to get this done.
i have tried multiavchd but i think that its encoding the audio which may not be bluray compatible? I was just wondering if there was anyway i could change the audio before i put it in multiavchd? or will multiavchd only change the audio as i want the video untouched.
Thank you so much in advance for the reply's.
some media info below.
i want this file basically with a menu and the video untouched, any help would be awesome.
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=2, N=75
Codec ID : avc1
Duration : 45mn 53s
Bit rate mode : Variable
Bit rate : 4 347 Kbps
Maximum bit rate : 5 500 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.157
Stream size : 1.39 GiB (98%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 45mn 53s
Bit rate mode : Constant
Bit rate : 93.5 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 30.7 MiB (2%)
Text
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Duration : 45mn 53s
Stream size : 0.00 Byte (0%)
Encoded stream size : 0.00 Byte (0%)
It's not possible without re-encoding (as an authored blu-ray disc )because 1280x720p29.97 isn't supported by blu-ray standard . It needs to be 1280x720p59.94, either with duplicates or a frame repeat flag
The audio isn't compliant either (AAC not supported by BD standard, needs to be re-encoded as well)
You can do it as a data disc, if your player supports it (non authored, no menu) -
BluRay wants to see ac-3, WAV (or 'LPCM') or DTS audio codecs. For AVC video (H264), profiles should be High @ 4.1
Edit: poisondeathray beat me to the punch.Last edited by Dougster; 25th May 2014 at 14:59. Reason: additional
