    Nov 2006
    Australia
    Hi guys.
    Sometimes shows recorded on Windows Media Center have no volume when playing them back. It happens to programs on different channels. Everything was working fine for the last year or so.
    I'm using a Quad DVB-T Receiver:
    >http://www.digitalnow.com.au/dvbtcards.html
    I disabled the tuners in Device Manager to test them 1 by 1 with live TV. They all worked normally.
    Win 7 64bit
    Any ideas? Codec issue?
    Thanx.
    Have you checked so they contain audio? Try MediaInfo.
    Maybe several audio tracks and one silent?
    Nov 2006
    Australia
    Hi Baldrick,
    I did but from memory MediaInfo didn't list the audio for any wtv files that I used for comparison - even those that had working sound.
    Aug 2006
    In my experience, MediaInfo does not list any audio information when analyzing wtv files, although it does show video characteristics and N. American closed caption details.
    VLC does show audio information, if audio is present. Play the .wtv file then click Tools->Media Information and the "Codec" tab on the Media Information window.
  5. You can try using Windows's WTV to DVR-MS conversion tool, wtvconverter. I think MediaInfo works with DVR-MS.
    Aug 2006
    That was the first thing I tried, and it does not work.
    Feb 2004
    Australia
    The first thing to do is to retune the dvb-t receivers and retest ... broadcasters do make minor changes occasionally which could be the root cause to the problem.
    Next would be to install a new hard drive and retest ... small hard drive performance glitches can also trigger the problem.
