Results 1 to 1 of 1
  1. Hi all the cats, but I have a problem
    using ffmbc to encoding in xdcamhd422 don't work
    using ffmbc to encoding in xdcam IMX50 = does work (ffmbc -i input.avi ... -target imx50 output.mxf)
    I'm not able to find a codec wich I can directly recall in my NLE to export .mxf files from NLE, so I wonder: can I export the .avi uncompressed file to a VFW-dummy codec or into a .avi or .avs that do a "bridge" that recall ffmbc and generate finally .mxf xdcamIMX50 file?
    My nle can export to VFW codecs, hoewver also in direcshow codec if installed
    thanks
