  1. Just learning..
    May 2014
    India
    Hi,
    Is there a MKV cutter which only cuts a part of a file. For e.g. I want to cut an action scene from a movie for 3 mins. MKVMerge is good for remuxing but i find it taxing for this purpose. Is there an alternative?
    Don't need a converter/encoder just a cutter/splitter for MKV files.
    Thanks much.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    MKV (H.264) and most other highly compressed formats are not very good for editing, especially if you want frame-accurate editing.
    To avoid sync problems you would need to edit on a keyframe and those are very widely spaced in the H.264 format, sometimes 10 seconds or more.
    You could try AVIDemux. Or try some of our other editors in: http://www.videohelp.com/tools/sections/video-editors-h264-avc
  3. MKV Cutter might also be worth a try, also search the forum, there are a bunch of similar threads here.
    I added a mirror download to your great MKV Cutter. Even if it's alpha. I hope it's okey.
  5. Yup, no problem.
  6. Just learning..
    May 2014
    India
    Thanks all. Testing Mkvcutter now..
